help !!!!!!!!!! my 2006 Pete 379 has no power to heater windows or mirror heat
Discussion in 'Trucks [ Eighteen Wheelers ]' started by alanbigwheels, Oct 20, 2013.
  1. alanbigwheels
    alanbigwheels Bobtail Member
    16
    Aug 16, 2013
    Saskatoon Saskatchewan
    Issue was a relay behind the dash
  3. 1johnb
    1johnb Medium Load Member
    542
    405
    Jun 13, 2012
    New Paris Ohio
    A little just for your information. If you ever need to work on a 379 fuse block wiring on the back side. (I had 1 catch on fire). Pull the air filter housing and the elbow that goes through the cab. You can pull the fuse block assembly out of the cab through the elbow hole. And have much more room to work on it.
    GrapeApe Thanks this.
  4. Imontoya
    Imontoya Bobtail Member
    22
    Mar 8, 2013
    06 Pete 379 had the same thing. Chicken lights, abs, window and mirror heat wouldnt work sometimes then have out. Ended up being the reley behinde the dash.
