Help Needed on a 2002 volvo N14 engine
Discussion in 'Trucks [ Eighteen Wheelers ]' started by pavel94, Feb 10, 2012.
  1. pavel94
    pavel94 Light Load Member
    164
    21
    Nov 22, 2010
    Waterford MI
    I have a N14 that keeps on drinking coolant we put a new head kit in it and still drinks it. its not leaking on the ground at all. We just cant find the problem. the engine seek to be working great. but just cant find the problem with the coolant. Please help?
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Are you sure its not pushing it out the radiator overflow host while under a load check the radiator cap also have you done any oil samples cummins has issues with inj precups on n14 and m11,ism engines
    s
  4. thehammer69
    thehammer69 Light Load Member
    53
    15
    Oct 31, 2008
    Goose Creek, SC
    Maybe a pinhole leak in a cylinder liner due to liner cavitation....this would mean time for a rebuild
  5. QUALITYTRUCK
    1,810
    1,772
    Jun 14, 2009
    romulus,mi
    drop oil pan and pressure the coolant system look for coolant coming down one of the cylinders.good luck.
  6. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Was it milky in the valve cover? Is there any condensation on the fill tube or dipstick? If not replace the radiator cap and place a gallon jug at the end of the overflow tube and secure it. Then test run it. How much water is it losing?
  7. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    I would drain the fuel filter and look for coolant, the injector sits in a copper sleeve, and if you use DCA4 they corrode away quickly.
    If you go to the Diesel Garage site they have a section called Handy links and there is a writeup on how to do a proper and complete bottle test.
    As suggested the Rad Cap is very important, and if it is leaking into the crankcase the oil fill plug will have a foam on it.
  8. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    What kind of head work did you do? Just gaskets? Did you do all three? Did you replace any heads?
  9. Starline
    Starline Medium Load Member
    357
    251
    Jun 1, 2011
    Middle Tn
    Check the water lines going to as well as the cab & sleeper heater core for leaks
