Mercedes mbe 4000 , code ecu128 sid 054 fail03
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BennyG, Jun 9, 2023.
  1. BennyG
    BennyG Bobtail Member
    Mercedes mbe 4000 , code ecu128 sid 054 fail03 , Thanks
  3. Animosus
    Animosus Heavy Load Member
    710
    2,798
    Dec 7, 2015
    SE Wyoming
  4. BennyG
    Im confused , this engine does not have a grid heater . what happened was , truck was going down the interstate and the turbo let go , on the intake side . changed the turbo and charge cooler . truck went out on job for a day and kicked on the check engine light , pulled the egr valve and the flap was stuck , due to carbon build up , clened that up and got it working , seems to run good , just has the light on now , any input ? Thanks
