Help! Needing a 2SC2312 final
Discussion in 'CB Radio Forum' started by Turbogus, May 31, 2011.
  1. Turbogus
    Turbogus Light Load Member
    56
    Oct 16, 2010
    Philomath, Oregon
    Hi folks,
    This may be beyond any novice repair but I got this radio for free so if it's within my capability I'd like to see if I can get this bugger working.
    The radio is a Uniden Pro520XL mfg in Taiwan. [​IMG]The Ch. lights work properly and I can hear the familiar "pbt" when keying up, but no signal with a known good antenna within proximity of 50 ft of the monitoring rig.
    I've taken the case apart and cursor look at the pcb there's no sign of burnt circuits or broken connections.
    My interest in this radio is that it fits in a moulded console in the ceiling of his van. This 520 has a conventional 4 pin mic connection that is desireable, His 510 he kaputted by thinking the mic connection was a twist type when actually it was a 6 pin half moon type.
    From another forum it was supposed that the final may have gone kaput, however the 2SC2312 is no longer available (except for the fakes) what can I do?
    Thanks and a lift of the lynch lid for your help.
  3. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    Turbogus Thanks this.
  4. Turbogus
    56
    Oct 16, 2010
    Philomath, Oregon
    Is it certain that the 1969 will work properly with the little Pro520xl?
  5. Big_m
    881
    265
    Oct 13, 2009
    Central Maryland
    The 1969, 1307, 2312 can be swapped out. The problem is finding them.
  6. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    AND .....
    They were widely used in low power HAM rigs too .....
  7. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
  8. Turbogus
    56
    Oct 16, 2010
    Philomath, Oregon
    I've been burner by Copper before (some call them Crapper) with incorrect items being shipped, so I'm dubious about their integrity.
    Yesterday I got the final pulled (and wrestled to the ground), it turned out to be a 2166......
    no sooner than I had that done and the PCB somewhat cleaned up and I received a message from weazel66 that my symptoms may not be final power transistor related..............:mmeek: this after several others from other forums reccomended finals replacement.
  9. Big_m
    881
    265
    Oct 13, 2009
    Central Maryland
    RF Parts sells the 2C2166 also.
  10. Turbogus
    56
    Oct 16, 2010
    Philomath, Oregon
    Got a genuine Mitsubishi 2166 on the way, and as I don't want my friend to wait so long I found out Uniden sells factory refurb 520's for $35 so when I get that transistor I'll use the old 520 as a test bed.
  11. M818
    M818 Light Load Member
    286
    147
    Apr 27, 2011
    Dallas, Texas
    Was there any kind of bracket holding that transistor tightly to the case? Hate to think things are so crappy they would not have something there. No conduction to the heatsink=cooked final. Looks like a nice ceramic insulator tho.
