Help... no oil pressure on Cummins ISX 15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by GatorKenworth001, Dec 5, 2019.
  1. AModelCat
    160,584
    It won't be if it ran for even a few minutes with no oil pressure......
  3. AModelCat
    160,584
    @pushbroom is saying you should drop a cap or two to make sure the bearings aren't damaged from oil starvation.
    Shawn2130, spsauerland and pushbroom Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,724
    9,054
    Jul 12, 2017
    That doesnt necessarily mean a whole lot to me.
    Oil pumps dont regularly fail to the point of no pressure. If it's being driven and has oil it's working. In order to create pressure you need containment. Your crank and cam bearings are the main source of that containment.
    Drop the pan. Inspect the suction and pressure tubes for proper installation and obstructions. Drop #4 and #1 rods and mains while you in there. Pull the valve cover and have a look at the cam bearings too. Have you cut open old filters yet?
  5. GatorKenworth001
    GatorKenworth001 Bobtail Member
    23
    7
    Jun 9, 2013
    Pulled the oil pressure sensor out today and started engine. Not 1 drop of oil came out the hole. Shop said if that pump was doing anything, at all, there should be oil coming out of the hole. We already did a manual dial gauge yesterday morning, nothing.
    pushbroom Thanks this.
  6. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
    Time to drop the pan and hope for the best with all the bearings in the engine being ok.
  7. AModelCat
    160,584
    Not to mention the top end too.
    Roberts450 Thanks this.
  8. GatorKenworth001
    23
    7
    Jun 9, 2013
    Well, the oil pressure suddenly stopped while at shop getting starter replaced. After they started it I noticed red light on the dash. We shut it down immediately
  9. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    You drove it into shop, they changed oil filter and now no oil pressure?
    If the last time you changed oil and filter the oil pressure jumped back up then I would say the inside of the engine is dirty and clogging the filter.
  10. GatorKenworth001
    23
    7
    Jun 9, 2013
    We tried two different new filters with the same result.
  11. Mattmanstroked
    185
    279
    Nov 24, 2019
    Kind of acts like it lost its prime, but you were already having oil pressure problems. I would be dropping that oil pan for a look. No oil flow at all would have me looking at oil pump and oil pickup tube.
