Help... no oil pressure on Cummins ISX 15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by GatorKenworth001, Dec 5, 2019.
  1. GatorKenworth001
    GatorKenworth001 Bobtail Member
    23
    7
    Jun 9, 2013
    Yes sir, that’s the plan on Monday. Plus, if the filter is totally clogged, it does have a filter bypass valve. We checked it. It seemed in good working order and was clean.
  3. sledhoz1
    sledhoz1 Bobtail Member
    Dec 29, 2016
    WI
    Hey, the pickup tube cracks where soldered, seen this enough. Forget about the relief valves, misc, etc...
    Drop the pan and inspect the pu tube. Times a wasting, no roll-no mula !!
  4. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Bet your engine is anchor now. You said mains were done 138K ago. Someone did something wrong. It start develop oil pressure drop. The final straw was dry start after oil filter change. Look for bearings out on the bottom or overhead.
  5. GatorKenworth001
    23
    7
    Jun 9, 2013
    Well, pan is off. Pressure relief valve is jammed slap all the way up inside pump and will not come out for nothing. Replacing with brand new oil pump and new pickup tube also.
    Will update tomorrow
  6. pushbroom
    pushbroom Road Train Member
    1,779
    7,317
    Sep 1, 2012
    No other shrapnel in the pan? That is usually what jams the regulator in the pump
  7. GatorKenworth001
    23
    7
    Jun 9, 2013
    None reported.
  8. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    Any thoughts on pulling a rod and main bearing cap to check bearings and crankshaft.
  9. GatorKenworth001
    23
    7
    Jun 9, 2013
    They checked #1 and 4. Said they looked clean. No unusual wear. Saying everything on top end looks clean too. I have to admit, this time around, for a Cummins it idles real smooth and quiet. Almost as quiet as a paccar.
    Mattmanstroked Thanks this.
  10. GatorKenworth001
    23
    7
    Jun 9, 2013
    Replaced with brand new oil pump. New oil and filter. Engine is running great. Oil pressure @ 675 rpms is 25 psi, running down the highway @1400 rpms 35 psi. Running smooth and nice. Keeping my fingers and toes crossed.
    bzinger, Mattmanstroked and Roberts450 Thank this.
  11. Goodysnap
    Goodysnap Road Train Member
    3,724
    9,054
    Jul 12, 2017
    Hope your shop shimmed the pump gear lash. I'd be taking the old one apart to find out what happened.
    spsauerland Thanks this.
