Help No power at the dash only when temp outside drops below 32 degrees
Discussion in 'Peterbilt Forum' started by batwrangler, Jan 26, 2013.
  1. batwrangler
    batwrangler Bobtail Member
    47
    wilton ny
    its a 99 379 ..changed relay switch inside the dash behind the fuel gage changed all fuses and plug in relays changed selenoid and starter still change key switch.. nothing,,,any thing else?
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
  4. twolane
    twolane Medium Load Member
    468
    252
    Dec 16, 2010
    Arizona
    Don't know about the Pete but some other brands have a fuse inside the battery box. Usually a spade type in an in-line fuse holder. Some trucks have more than one. Check inside the battery box.
  5. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Does the cab still have power like lights and Such, pull the left kick panel and pull the two screws holding the fuse box in and check the back side of the box petes have a common problem with leaky windshields could be moisture freezing on the back side of the breaker
