Help...not sure how my truck keeps losing water.
Discussion in 'Volvo Forum' started by Aceswild33, Sep 22, 2012.
  1. Aceswild33
    Aceswild33 Bobtail Member
    16
    Jun 28, 2012
    Elizabethtown KY
    I have had several issues lately with my 03 Volvo with a volvo d12 engine. I replaced the turbo and recently replaced the thermostat. Now every 150 miles i am having to add a gallon of water. I see no visible leaks. The oil looks fine and not a milky color. It isn't blowing out any white smoke. Everything else seems to be working accordingly. Hopefully, it is just something simple. If you have any suggestions, just let me know. Thanks Tammy
  3. cuzzin it
    cuzzin it Road Train Member
    3,638
    11,235
    Jan 19, 2008
    Berea, KY
    i had same problem with 07 red head cummins... turned out to be diaphram on egr
  4. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    get your oil and coolant tested. That would be a good first start.
  5. Aceswild33
    16
    Jun 28, 2012
    Elizabethtown KY
  6. WorldofTransportation
    WorldofTransportation Heavy Load Member
    702
    577
    Sep 20, 2009
    Your mother
    I bet you have a hole in a liner... it is probably pushing the water out the overflow tube... Having said that take it to a shop and have them pressure the system up and see if you have a hose somewhere leaking... One of mine did this about 6 months ago was just about to call cummins and have them quote me the price of an inframe when a mechanic friend of mine told me to stop by his house and we would pressure the system.. Turns out the water tank (clear plastic) had a crack in the seam and under pressure it was leaking like a spiget..
    It could be several things.... I am just speaking of what it would normally be with my luck on the liner.. best of luck
  7. HwyPrsnr
    HwyPrsnr Medium Load Member
    471
    344
    Apr 22, 2012
    Anywhere, USA
    Had the same problem with my cummins. Was the egr.
  8. Aceswild33
    16
    Jun 28, 2012
    Elizabethtown KY
    Thank you. I do know our Volvo engine does not have an egr. But I will take it and get it tested. Thanks a lot.
  9. HwyPrsnr
    471
    344
    Apr 22, 2012
    Anywhere, USA
    Sorry. Didnt pay attention to the d12. Paying too much attention to the next person and their cummins. Sorry again. Take care and good luck driver. I dont know anything about a d12 sry.
  10. Aceswild33
    16
    Jun 28, 2012
    Elizabethtown KY
    Awe that's okay thank you for giving your input though. I appreciate all the help I can get. Have a good night.
  11. tank4life
    tank4life Light Load Member
    155
    105
    Feb 18, 2012
    Makes sure it is not the air compressor head gasket. It could be going into the air system and is being expelled by the air dryer.
    cadillacdude1975 Thanks this.
