Help on leaking ad-sp air dryer.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 379wheathauler, Dec 22, 2011.
  1. 379wheathauler
    379wheathauler Bobtail Member
    30
    4
    Sep 5, 2011
    Montana
    I have a ad-sp air dryer that the purge valve was leaking,so installed a new one and still leaks only when engine running. Someone told me put a new governor on so I did and still leaks. I installed a new air dryer and the purge valve leaked, so I put a new purge valve in it also and it still leaks. It starts to leak right after it purges. When you shut the engine off it slowly stops.
  3. Infrared61ranger
    Infrared61ranger Light Load Member
    149
    36
    Dec 15, 2011
    killeen,tx
    you confused the hell out of me you did everything i would have done. did you clean the surface before you replaced the valve and did you add a gasket and are the screws stripped or anything
  4. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    What pressure does it build up to before it purge's?
  5. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    The unloader valve orings in the air compressor are passing air. Install an unloader kit.
  6. 379wheathauler
    30
    4
    Sep 5, 2011
    Montana
    pressure build to 130 orange needle stays white needle drops.
    I put a unloader kit in it.
    Maybe I need a new compressor.
  7. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    OK then, remove the signal line from the air dryer and plug it. Run the compressor through a couple cycles and see what changes.
