Whats the difference between driving my truck and driving a standard transmission in a car? I'm supposed to test drive one today and I figured I'd just wing it.
I know this is supposed to be strictly trucks, but I figured this would be a good laugh at least!
6 speeds of confusion, here I come. No double clutching, no floating? Shifts in a straight line, with no neutral in the middle?
Geeze.... this is going to be confusing.....
Help! Out of my element!
Discussion in 'Questions From New Drivers' started by GiantBeard, Mar 3, 2016.
For one you will find pushing the clutch in a car very easy after driving a truck.
Dominick253 and GiantBeard Thank this. -
You'll need to use the throttle when taking off from a stop or else it'll stall. When you shift up, just clutch in and go to the next gear, then release. Downshift is the same. Clutch in, drop a gear and clutch out. Sometimes I'll blip the throttle with the clutch in when downshifting just to make it easier on the clutch when I let it out but its not really neccessary to do that.
GiantBeard and Straight Stacks Thank this. -
GiantBeard Thanks this.
The problem with driving a car with a stick shift after driving a truck is you will be trying to double clutch it. Then when you get back in the truck you're going to be grinding gears. The car trans is synchroed and the truck is not.
rabbiporkchop and GiantBeard Thank this. -
you dont have a license at all ??
When you get in the truck say "Wow, haven't seen one of these since the truck antique show!"
GiantBeard Thanks this. -
Of course I do! I've just never driven a standard transmission 4 wheeler before and I'm in the market for a new (used) car.
I also never knew that it is considerably cheaper to buy a car out of state and have it shipped.... I'm test driving here and if I can't low ball the dealer, I'm having it shipped from Texas.Blackshack46 and ajohnson Thank this. -
