grapeape tell me what the fault codes are for a 2015 Peterbilt 389. Has a Paccar MX13.
Right now codes 3251, 94 and 5442 are showing up.
HELP PLEASE ! Can anyone, maybe even
Discussion in 'Peterbilt Forum' started by junell, Jan 26, 2018.
SPN 3251 - DPF Soot Load
SPN 94 - Fuel Pressure
SPN 5442 - Fuel Rail Pressure
Have you changed fuel filters recently, ran low on fuel, or fueled recently where you may have gotten bad fuel? With active fuel pressure faults, it may not be able to do an active regen, causing a high soot load. That's just a guess, FMI's will tell me more.Pamela1990 Thanks this. -
I do have most of the conversions in a spread sheet, they don't allow Excel attachments here, so I uploaded them here:
MEGAPamela1990 and QUALITYTRUCK Thank this. -
GrapeApe I know this is a pretty old post but hoping you might be able to help me out, I have a 2015 KW T680 w/MX13 EPA13, change out my engine mounted fuel filter and now I'm getting SPN-94 FMI-1 and randomly getting SPN-94 FMI-18 at idle if i idle it up to 1200+ Rpm the code go away after about a min but come back once i idle back down. Thanks
@GrapeApe was last here in March of this year.
