HELP!!!Priming my fuel system!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by local-trucker-dude732, Feb 14, 2009.
  1. local-trucker-dude732
    local-trucker-dude732 Bobtail Member
    keansburg,nj
    I recently ran my 94' fld 120 low on fuel, enough to get some air in the system, but not completely dry, now at idle the motor bogs down every now and then, like i have an air pocket in the fuel system somewhere? i filled the fuel filter through the cap on the top of it but still have bogging problems often at idle, even after driving it for a while, i know i have to prime the fuel system but i'm new at this and need to know the complete procedure if anyone could please help!!!! Thank for your time!!!!!
    p.s.- its a 94' Freightliner FLD 120 with a cummins M11, Thanks Again:biggrin_25525:
  3. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    you say you filled filter thru cap on top. is this a Davco ? big black ring at bottom of glass. black cap on top? can see filter cartridge ?
    Lilbit Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    Yah, sounds like a Davco. Make sure the o-ring is still on the top cap.
  5. PaulE
    413
    145
    Jan 15, 2009
    Verona Wi
    ill assume its a Davco, if you did not disturb the large ring at bottom then take top cap off.remove o ring from cap carefully...clean o ring,underside of cap and top of glass where o ring seals with diesel fuel . put o ring back on cap .use your finger to dab fuel on o ring and sealing area on top of glass. both should be wet . screw cap back on just till o ring contacts glass. then 1/2 to 3/4 turn more. should just be snug.
    will be away from site rest of day so if that dosent work someone will help you. good luck
    WiseOne Thanks this.
  6. local-trucker-dude732
    keansburg,nj
    not the glass type, its the metal one like an oil filter, should i prime the whole fuel system? and if so what would the procedure be???
  7. ampm wayne
    ampm wayne Heavy Load Member
    945
    746
    Jan 13, 2009
    bloomington,in
    My experience with air in the fuel system is that once you get it running and can keep it running it will be fine. I wonder if you need to replace the fuel filter. You may have sucked dirt into the filter from running low on fuel. Also,do you have a water seperator? If I was you I would change both filters and see if that helps. If not you may have an injector problem. Also,run some fuel conditioner in your next tank of fuel.
  8. kentuckyrambler2
    kentuckyrambler2 Light Load Member
    85
    55
    Jan 18, 2009
    Pulaski, TN
    local-trucker-dude732:
    It sound like you picked up trash from fuel tank, and it has affected your injectors.
    This is what I would do.
    (1) replace the fuel filter
    (2) fill new fuel filter with automatic transmission fluid before installing it. ( ATF, or dextron 3 )
    The automatic transmission fluid will clean the injectors and works better then fuel treatment or injector cleaner.
  9. PaulE
    413
    145
    Jan 15, 2009
    Verona Wi
    you guys are thinking too hard. the only thing that happened was he ran low on fuel.your diagnosing too far ahead. secondary filter is not full of fuel. fill filter as full as possible . theres air in secondary filter . primary will not be full unless its gelled or its at capacity to hold dirt...get air out before going further
