HELP. pwr steering overheating 6NZ in 379
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jeron379, Nov 22, 2011.
  1. Jeron379
    Jeron379 Bobtail Member
    22
    6
    Aug 15, 2009
    Moncton New Brunswick
    Truck has been through 3 shops so far. Bought it 2mths ago and on the first trip out the pwr steering hose from the resevoir to the pump kinked over and starved the pump. (Truck dealer had installed non oil resistant hose). Replaced the hoses with proper lines. Made it a few days and noticed the lines were getting so hot they melted the plastic sheathing off of them. Not long after the hose let go. Completely cooked. Replaced pwr steering pump and installed new lines next. Made it a week and its puking fluid. Found a shot o ring on the pump. Been bout two wks now and just got a call from the driver its leaking again so I suspect the line is cooked again or the pump fitting o ring.
    Any ideas on what is goin on here??
    Truck is 01 379 6nz.
  3. Heavyd
    Heavyd Road Train Member
    7,764
    6,203
    Feb 4, 2009
    When you have a pump or gear go like that, sadly, you need to replace everything! No matter what you do, if you only replace the pump, metal is still in the gear. If you only replace the gear, metal is in the pump. Metal left over will ultimately make it's way through everything again. Pump and gear needs to be replaced together. Lines have to be removed and flushed, in your case, the proper ones need to be installed. Power steering reservoir needs to be washed out and a new filter installed. Finally, refill with new fluid.
  4. Jeron379
    22
    6
    Aug 15, 2009
    When we did the pump it got new lines, new filter and fluid.
    When you say gear u mean the steering box also or ?
  5. power freak
    power freak Light Load Member
    220
    60
    Apr 23, 2009
    Yes the box is also called the steering gear.
  6. The Truckist
    The Truckist Medium Load Member
    342
    245
    Sep 11, 2010
    Of course you've figured it out now the hard way but some of those power steering systems, if not ALL of them, require regular filter changes of the power steering fluid. Some are more forgiving than others. You'd be surprised how many drivers had no idea there was even a filter inside the power steering reservoir. What happens...and now you know...the filter gets plugged and all kinds of problems ensue. The heat & elevated pressures will destroy seals and rubber creating more than leaking problems.
    The filters rather cheap, (NAPA handles 'em too), it's convenient to get to in most cases and it'll save your power steering system a lot of stress.
    Like the other poster said...since you've had a failure, better flush and clean it all. Seal around shaft in steer box will probably be in order also.
  7. Heavyd
    7,764
    6,203
    Feb 4, 2009
    Yah, sorry, power steering gear or box.
  8. Jeron379
    22
    6
    Aug 15, 2009
    Thx! So a down power steering pump puts aluminum through the system and the only way to get rid of it is to replace everything. Ouch!
    I didn't see any sign of aluminum in anything when we did the pump swap. That normal?
  9. Dino1968
    Dino1968 Light Load Member
    Great info here Thanx to guys who are sharing the knowledge !
    On 1996-2000 model KW T600 or W900 where is this filter located?
  10. The Truckist
    342
    245
    Sep 11, 2010
    Dino...it can be found INSIDE the power steering reservoir. A couple examples I know of are...on a couple CAT powered trucks I owned, the canister was steel and access to the filter inside was by removing a single bolt from the top. My current 07 379 with Cummins...a band clamp around the center section will allow access inside the reservoir.
    I've never had one where the filter was outside the canister but that don't mean there are none out there. Also some trucks, IIRC, may have coolers for the power steering fluid.
    This is a couple of the filter numbers...but check before you buy.
    Napa Gold #1637
    FRAM #C1720
    Dino1968 Thanks this.
