Help replacing Eaton shifter.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hhmag70, Jun 10, 2012.
  1. hhmag70
    hhmag70 Light Load Member
    103
    59
    Mar 18, 2012
    Trevorton,Pa
    I am looking for a little help with replacing the factory shifter assembly to an old style shifter with the seperate t-handle splitter. When I slid the plastic cover down on the unit I see just 3 air lines hooked up to it. Is the conversion as simple as just hooking up the correct lines to the correct inlets, or is there something more to it when going with the old style? Thanks for any help.
  3. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    Yes it is as easy as putting the 5/32 lines in the correct spot. Mounting it can be difficult to make it look neat. Sometimes the screws line up sometimes they don't
    hhmag70 Thanks this.
