Help shifting a 6spd Eaton Fuller?
Discussion in 'Questions From New Drivers' started by CruzControhl, Dec 30, 2018.
  1. CruzControhl
    CruzControhl Light Load Member
    163
    79
    May 7, 2018
    Getting my automatic restriction removed and testing out on a 6spd Eaton fuller. I was told its synchronized so i thought i could grab any gear at anytime. Not so..i grinded 2nd and 3rd a couple times trying to downshift. Now i know you have to get the rpms right and i can do that just not perfect everytime.
    I wanted to see if anyone whos drove or drives the 6spd Eaton could just also give me a good idea of gear in correlation with miles per hour as you accelerate up and into 6th gear and then back down.
    I understand rpms should be enough and engine sounds, its just i dont have alot of practice time on this vehicle. So i want all the info i can get.
    Even if you just have a theory.
    I know its comfortable upshifting at 1600 to 2000 rpms and i let it get down to 1000 rpms before down shifting.
    A couple times i missed a gear on the way down so it was just a little confusing deciding which gear to choose for recovery. Hence mph in correlation to gear would help even know i know things like how much acceleration power you need could affect how long you hold a gear.
    Also it being a 6spd i cant use the
    4+5= 9th or 2+5= 7th gear so on trick.
    So any help is appreciated!
  3. CruzControhl
    163
    79
    May 7, 2018
    Also in 1st gear can i just slowly let off the clutch and then apply gas (after clutch is fully released ) or should i slowly let off the clutch as i begin to apply the gas?
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I had a 5 speed mack a very long time ago and I do not recall exactly where I shifted at. The range is from 600 idle all the way to 2300. It's not a very fast truck. Engine starts to wake up about 1300. Begins to pull ### off at about 2000.
    All heavy truck engines have a torque RPM below which it will refuse to pull anymore and begin to lug, buck, bounce or fight you. Or even stall. That is your bottom number. Find a big hill, hit it in one gear stay in it until that nose starts hopping. There is your torque RPM.
    You can literally hear by ear it's song. If it's coughing a fit it's not working well in too high a gear, downshift one GENTLY and Smoothly. If you get it in there, music should be the result. If you push it too much you will feel as if you about to lose your drives or your turbo screech icepick in your ears. Time to shift up.
    There is also a high horse power RPM. today's trucks are engineered to run about 400 or 500 RPM apart between the two RPM's for either wind it out shifting or progressive shifting (Which is beyond the scope of this post)
    Your rig should be at least 500 RPM higher than that point at which she bounced or bucked on you at or under Torque RPM. You can probably find the engine stamp on the block, google it by make and model and discover it's operating chart which all engines have. Which is a curve expressed between two RPM's for shifting.
    CruzControhl Thanks this.
  5. wore out
    wore out Numbered Classic
    17,375
    215,821
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Why does everyone think there is a magic speed to gear correlation without knowing rear ratio and tire size. Even then we have to plug it in to get close.
    Here's a hint start at your best guess. Dont push hard on the stick, if it doesn't fall in gently bring up the rpm if by 1500 it doesn't fall in go down one hole repeat.
    Is this in a M2 business class by chance?
  6. Ridgeline
    22,741
    123,660
    I haven't seen a class 8 with a 6+1 in it, seen a bunch of fl-50/60s and m2s with them
    wore out Thanks this.
  7. CruzControhl
    163
    79
    May 7, 2018
    Class b 08 (not sure of year) international 6spd 4300?
  8. rolls canardly
    rolls canardly Road Train Member
    1,643
    4,168
    Feb 7, 2009
    mt. pocono. pa.
    Freightliner M2 106 is what I drive and its easy - peasy.
    Someone once said they stopped reading a post I put up after I said something about 2500 RPM.
    The 3126 Cat sings like a bird at that, 2000 is good for a steady 70 MPH all day.
    I have 19.5 tires on and usually start out in 2nd, run it up to 1500, shift, 1500 again, shift, etc.
    Coordinate depressing the clutch so it's about a half second before you move the shifter.
    Same with on the way down, its a slow progression - w/clutch all the way in, select next lower,
    let it out easy, and on and on. Don't like to over-rev either going up or down,
    as there is no load, and it truly is just over-revving the engine.
    Get on a side road with no one behind you and just do it.
  9. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    I have a 6 speed international 4300 flat bed tow truck and it’s fully synchronized.
    No double clutch or rpm matching required.
    rolls canardly and CruzControhl Thank this.
  10. rolls canardly
    1,643
    4,168
    Feb 7, 2009
    mt. pocono. pa.
    I actually do the whole clutch release thing first, and then put it - to it.
    I buy the parts, and I do the labor, (clutch,) - and don't slip it unless absolutely necessary.
    The 1500 RPM thing is just a reference of what it sounds right to shift at - for me, on this unit.
    I follow thru with pedal to the metal each time- smoothly, with no lurching or stalling; it must work?
    Got the comment once from someone that I had a "Ham - Fisted driving technique."
    I'm not racing anyone, but I don't go slow either. Shifting to me is to get me up to warp speed.
    I'm not delicate doing it, but I don't grind gears either. Hesitate with slight pressure and it drops in.
  11. wore out
    17,375
    215,821
    Jun 5, 2013
    My 98 4900 came with a 6+1 a DT530 and 5.38 rears. I floated them just like bout anything else
    snowman_w900 and Humblepie Thank this.
