hello tuckers.im studing for class a cdl. right now im trying to get cdl permit so i can get class at community college.
i would love to have some guys ask me random questions like test questions.
just to see if i can get it right.![]()
help this kid to get cdl permit
Discussion in 'Questions From New Drivers' started by DeafTrucker, Jan 28, 2011.
How much tread is the minimum for your front/drive tires
How much play is too much for the slack adjusters?
What documentation are you supposed to have with you at all times? -
At what PSI is your low air warning device supposed to come on? What warning device is required?
2 logs, transation, im not sure. care to answer it correctly that i got wrong
What? lol
Go to www.cristcdl.com and take the practice test, the are FREE! and every question on there is on the DMV test, there even worded the same.
American Trucker -
thanks man, taking practice ones and will read cdl manual again too
low air psi warning is for your brakes...not tires. and the correct answer is 55 psi, and a red light on the dash must come on, with optional buzzer
2" of play or less on slack adjusters. 1" is an acceptable answer since it is a better standard.
Steer axle is 4/32, drives are 2/32.
Always have your log updated, curret pre trip inspection, and any load documents or bills of lading. -
oh wow so i have to check tires air during pretrip inspection ?
you need to check the air pressure in the tires, and check to make sure your air compresser is building air fast enough, and check at what rate air leaks out of your air brake system with AND without the brakes applied...
heres how to do a pre-trip: http://www.thetruckersreport.com/tr...ivers/131546-proper-pre-trip-for-newbies.html
American TruckerFlying Dutchman Thanks this.
