Help...trouble shifting into 6th gear.
Discussion in 'Questions From New Drivers' started by Sheriff1/6, Jan 7, 2013.
  1. Sheriff1/6
    Sheriff1/6 Medium Load Member
    480
    505
    Oct 16, 2012
    Boise, ID
    Right up front, I'm a newbie and I don't know anything about mechanics.
    I drive a 2013 Volvo with an Eaton 9sp. Lately, when I try and shift into 6th gear, it won't go in until the rpm's are down to between 900 and 1000. It's a real pain when trying to get up speed to merge or climb a hill. I've tried varying the speed, rpm's, double clutching, and finally I tried slipping it into gear without the clutch. Nothing seems to help. There is a check engine light that came on a few days ago. The mechanic wasn't too concerned about it. Could that be telling me there is a sensor that has gone out, causing the shifting to be off.
    Any help would be greatly appreciated.
  3. Voltrucker
    Voltrucker Medium Load Member
    467
    133
    Sep 24, 2012
    West TN
    Just keep bugging the mechanic. If you drive a big company with several terminals, go to another terminal while on the road. Obviously the mechanic you told is just flat out lazy. NOT hard at all to change a sensor.
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    are you sure its not a 10 speed, try going from 5th flip the range selector and then go back to the 1st hole for 6th rather than the 2nd hole for 6th. there should be a sticker somewhere that shows the shift pattern or on the gear shift knob but they could always be missing. iv drove some transmisions that had some weird shift patters like 8-9 hole being reversed with 9th to the dash. or 9speeds where you shifted 1st threw 4rd skip 5th and then go back to the 1st hole on the top side. like you would on a 10 but skip the 5th hole.
    it sounds to me like your skipping a gear and thats why its not going into gear until the rpm are so low.
  5. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    also a sensor is not going to make it shift any different unless its a automatic. transmissions are mechanical just gears meshing together so a check engine light wont change how it shifts.
    Diletantte Driver and Voltrucker Thank this.
  6. Voltrucker
    467
    133
    Sep 24, 2012
    West TN
    True! Didn't think about that!
  7. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    What are your RPM's at when you shift from 5th to 6th (5-7th 10spd) there should be about a 300rpm drop between the gears. If you're shifting at say 1600-1700 rpm and it's dropping that low you have a 10spd instead of a 9spd so go back to the 1 hole instead of the 2 hole. You ain't the first driver that's had this happen so don't feel stupid. Climbed in an old international that had a 9spd with 5th on the high side back in the 1 hole took me almost 1/2 a mile to figure out that 5th wasn't on the low side felt like an idiot but it happens. Just have to laugh about it specailly when you get flipped off by a 6 month old in a car seat because you ain't going fast enough :biggrin_2559:
  8. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    That was my first thought, too....
    typical 9 speed transmission shift pattern
    typical 10 speed transmission shift pattern
    Shift patterns are on page 2 of the pdf's...upper right hand corner of the page. On the 9 speed, "low" is what you probably call 1st...."1" would be 2nd....and so on.
  9. Sheriff1/6
    480
    505
    Oct 16, 2012
    Boise, ID
    Well there you have it. All of you will be issued a PH.d. in the mail very soon. I, on the other hand, will be sent back to school to learn to read.
    I dug out the information on the truck and what do you know, it looks like a 10 speed to me. I have a load tomorrow and I'll figure it out before I hook up.
    Thanks for all of the help...Yes, you can laugh and tell your buddies. I will.
  10. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    don't feel bad it happens to everyone when switching from a truck with one shift pattern to another.
    Ghost Ryder Thanks this.
  11. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    don't feel bad... I've driven 9, 10, 13 and 15 spds. I still get mixed up occassionaly.. lol
