Help, truck wont regen
Discussion in 'Kenworth Forum' started by +bluebell+, Nov 19, 2017.
  1. +bluebell+
    +bluebell+ Bobtail Member
    trying to do a manual regen on a lease Kenworth t680 2016 paccar mx13. Tried holding down the manual regen switch for 3 sec, then 5 sec hell i held it down for a whole minute the #### thing never started. 1st curb sniffer/kenworth i ever been in. Am i even doing it right??? Any other steps i need to do besides turning the truck on and holding down the switch?? o_O:roll:
    Thanks
  3. tech10171968
    tech10171968 Medium Load Member
    627
    851
    Nov 16, 2009
    Daytona Beach, FL
    In some trucks you have to release the tractor brakes first, then re-engage them before pressing the manual regen switch. Maybe KW is the same?
    +bluebell+ Thanks this.
  4. driverdriver
    driverdriver Road Train Member
    4,254
    5,282
    May 30, 2011
    Is the regen light on?
    You can push the switch all you want , if it's no t needing a regen you can't force it with the switch.
    AModelCat, Goodysnap and +bluebell+ Thank this.
  5. Makeajump
    Makeajump Medium Load Member
    443
    363
    Apr 19, 2014
    Texas
    If the DPF indicator light/message center is calling for a regen, Breaks set, cruse control on, it will respond to the switch depression with a steady green light on the switch and after a few seconds, the engine speed will start to increase, and there it goes! But it will respond as you have described if the system is not calling for a regen.
    +bluebell+ and driverdriver Thank this.
  6. kingkongslady
    kingkongslady Bobtail Member
    Have a 2011 Kenworth T660 with Paccar engine keeps showing low Def fluid then stop engine and derates. Doser has to be pulled and then clear code P3843. Before it can clear the derate. Has anyone else experienced this and figured out how to fix it?
  7. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Is your DEF actually low? If so, that could account for the P3843 ("Pump Module - Unable to Prime") code. Aside from that, I'd be looking at either a faulty DEF pump or blockage in the pickup tube.
  8. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Flashing DEF light means you have a fault in SCR system. To clear DEFOI (Diesel Exhaust Fluid Operator Induced) faults, you just about need DAVIE. First, you need to find why DEF pump is not building pressure. Common problems are failed DEF pump and usually DEF will pour out when you disconnect the harness, plugged DEF filter, failed DEF doser, or wiring issue. Then clear the code after the repair, put truck in Regen til temps reach 575 F @ SCR catalyst, road test immediately four about half hour on interstate in cruise so ACM knows SCR is working. Fault code will go inactive and you can then clear fault code.
    pushbroom Thanks this.
  9. Cool Breeze 7810
    Cool Breeze 7810 Bobtail Member
    Mar 17, 2019
    may need to change Def filter
    Tundra670 Thanks this.
  10. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Something tells me. Pretty sure he’s got it figured out by now
  11. FdEF
    FdEF Light Load Member
    70
    57
    Dec 5, 2017
    Ogden, Ut
    Come on bro it's only been a year lol
    S M D Thanks this.
