My brain froze .... and I got cheated out of my ice cream.......
I once had a truck that had a device that would crank up the engine if the interior temperature fell outside the comfort zone just long enough to bring it in range.....
Too cold? It would warm it up.....
Too warm? It would cool it down.....
WTF is that called? I would like to ask that one be installed.....
Help! What is the add on that fires the engine and heats/cools the cab?
Discussion in 'Experienced Truckers' Advice' started by Commuter69, Nov 16, 2018.
Optimized Idle?
Rideandrepair and tscottme Thank this. -
Opti-shake-you-awake-in-the-night.
MartinFromBC, Rideandrepair, TruckRunner and 6 others Thank this. -
Rideandrepair, tscottme and baha Thank this.
Rideandrepair, TruckRunner and x1Heavy Thank this.
Rideandrepair, 86scotty, Trucking in Tennessee and 1 other person Thank this.
I grew up in southern California. ... I have slept through earthquakes below 5.0..... lolRideandrepair, TruckRunner, otterinthewater and 2 others Thank this. -
Did X1 get a new account?
Samuelh and Opendeckin Thank this. -
APUs can be programmed to do that with timers. Set it for 30 minutes before you go to the truck and you are all comfy.
Rideandrepair Thanks this. -
It was and still is called optimized idle. However bad it used to be, it has changed as the industry has demanded.
The latest versions supplied with trucks that have bunk heaters only start the truck as the battery levels drop. In hot weather, it works as originally designed.Rideandrepair Thanks this.
