HELP! What is this and what does it do
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SommersOutWest, Dec 26, 2015.
  1. SommersOutWest
    SommersOutWest Bobtail Member
    9
    4
    Dec 26, 2015
    Mounted on DS just in front of batteries as picture shows. Full of what seems to be hydraulic oil. Air lines going to and coming from.
    I asked the idiot at the Pete garage and he didn't know either.
    Thanks in advance..............
  3. tucker
    tucker Road Train Member
    12,647
    40,424
    Jun 13, 2008
    IN
    That's a henway
  4. rachi
    rachi Road Train Member
    4,246
    5,231
    Feb 25, 2010
    SoCal
    Looks like a left threaded diesel deicer.
  5. SommersOutWest
    9
    4
    Dec 26, 2015
  6. SommersOutWest
    9
    4
    Dec 26, 2015
    I bought this truck a few weeks back. It's a PB 388 heavy haul. Came from Penn. I need to figure out if I can get rid if this component. The sight glass cracked and it's leaking.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,517
    6,576
    Aug 26, 2014
    It is an auxilary engine oil tank for add oil. Some had a push button for manual use. Others had sensors for an automatic ever fill system. It does have air pressure to it and must be released to put oil in it.
    Duckman1005, 12 ga and dclerici1 Thank this.
  8. Broker Bob
    Broker Bob Light Load Member
    155
    97
    Dec 8, 2015
    Its a tank for hydraulic fluid, If you look near transmission you'll see that you have a PTO.
  9. SommersOutWest
    9
    4
    Dec 26, 2015
    Thanks for both of your replies but it does have hydraulic fluid in it so it's not engine oil.
    I installed a PTO onto the transmission for a wet kit. This could possibly be for a factory installed PTO which is not present. I will have to check it out when the weather gets better.
    Thanks again.
    G13Tomcat Thanks this.
  10. dclerici1
    dclerici1 Medium Load Member
    525
    1,583
    Aug 1, 2012
    Shell Knob, Missouri
    Gotta agree with BXKid, if you trace the oil lines you'll find out. There is no reason for air lines to go to a hyd tank. Take your VIN # to a dealer and they should be able to look it up and tell you.
    12 ga Thanks this.
  11. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    It's awesome that the techs at the Pete dealer don't know what it is. Please save us and yourself a lot of pain. Stay Away from them.
