Help with ABS code 136: FO2 SID 004_A
Discussion in 'International Forum' started by IUFAN87, Apr 11, 2013.
  1. IUFAN87
    IUFAN87 Light Load Member
    220
    31
    Jun 22, 2009
    All Over
    07 9400i sets 136: F02 SID 004_A. Only happens under wet conditions.
  3. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    Right rear sensor. There is big green coloured connector under the fifth wheel on the left frame rail. This is a main ABS connector that commonly gets water in it. We disconnect them, inspect the pins for any corrosion and then pack them with dielectric grease and reconnect. You can also do the same for the actual sensor connectors too to help keep the water out.
    IUFAN87 Thanks this.
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    may be bad two pin connector (round, made by Wabco)
  5. Heavyd
    7,804
    6,253
    Feb 4, 2009
    Yah, it could be Wabco. I am just going with the odds. About 90% of Internationals here are built with Bendix.
