Help with another squealing noise from my D12...
Discussion in 'Volvo Forum' started by RogueX, May 2, 2013.
  1. RogueX
    RogueX Light Load Member
    110
    22
    Oct 12, 2011
    Indianapolis, IN
    2007 Volvo 780 D12 engine.
    This is a weird one. On cold starts I hear a squealing noise coming from the passenger side of the engine. It doesn't start squealing until about 30 seconds after the engine has been running, but then the engine changes tone and then it starts squealing. It only happens at idle speed, if I push down on the accelerator, even just a little bit, the squeal stops. Once the engine is good and warm it stops squealing too. I've never heard it any other time but#at idle speed. It has gotten progressively worse/louder over the last few weeks. Any ideas?
    Thanks.
  3. Big_jon
    Big_jon Light Load Member
    139
    60
    Apr 12, 2013
    Had a similar problem on a international truck. Replaced alternator and idler pulley and still a squeal. Turned out to be the belt.
  4. RogueX
    110
    22
    Oct 12, 2011
    Indianapolis, IN
    That would be great if it was just the belt but it sounds more severe unfortunately. I should mention that if I just press the accelerator slightly and hold it one particular spot while it's squealing, the squeal goes away and I hear air going puff puff puff, like the sound the air governor makes but much quieter, while it's doing that the rpms bounce ever so slightly. This engine has an exhaust pressure governor. I was worried it might be the turbo, but the fact that the squeal goes away and I'm not getting any smoke out of my stack rules that out doesn't it? Does anyone know about those exhaust pressure governors? Could that be it?
  5. RogueX
    110
    22
    Oct 12, 2011
    Indianapolis, IN
    Now that I really think about it that makes perfect sense. The exhaust pressure governor is there to keep the engine/exhaust temp higher at idle speed, so pressing the accelerator would cause it to disengage and that's when the squeal stops. The air noise I'm hearing could be from that pressure being released too. This making sense? Any Volvo expert or tech have any input?
  6. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    i think that you have a exhaust manifold gasket/joint leak.just had a couple of these in the shop.difficult to find.remove air cleaner (easy to do)while somebody revs engine causing sound,spray soapy water on manifold gaskets.also spray on egr clamp connections.good luck.
    RogueX Thanks this.
  7. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    It is the EPG d12 has what it's called a warm and hold function where the EPg opens up just to warm up the engine either way there should not be any squealing noise going on it is possible that you have some sort of gasket other from egr or one of the pipes that might leak a bit in my experience that is what squeals when the EPg goes on as far as the engine changing noise that's completely normal as well
    RogueX Thanks this.
  8. Jetsr6
    Jetsr6 Light Load Member
    131
    46
    May 20, 2011
    Mechanicsville, VA
    Yeah more than likely it's your EGR junk spray some soapy water around them when the engine is cold started up and watch the bubbles.
    RogueX Thanks this.
  9. RogueX
    110
    22
    Oct 12, 2011
    Indianapolis, IN
    Yeah, the tone change in the engine is caused by the EPG turning on, that's what I thought. Thank you. I know I do have a leak down there too cause I can smell it thru the AC system when idling. Hopefully this is all the same problem.
  10. RogueX
    110
    22
    Oct 12, 2011
    Indianapolis, IN
    Thank you, but the sound stops when I rev the engine. It's only there when idling, and only when the engine is cold. It stops squealing at about 150 degrees coolant temp from what I observed this morning. Also, I had the manifold gaskets replaced back in November. But I'll check the egrs.
  11. Jetsr6
    131
    46
    May 20, 2011
    Mechanicsville, VA
    nasriza
    Do you have any tips on how to keep these EGR gaskets from leaking I've replace the gaskets a few times now and the leaks keep coming back. thanks
    Marko992 Thanks this.
