Help with antenna on Volvo..
Discussion in 'CB Radio Forum' started by miynis63, Mar 27, 2012.
  1. miynis63
    miynis63 Bobtail Member
    27
    Dec 20, 2011
    Rancho Cucamonga
    I have an odd one I can't seem to pin down. I have the standard 2 cheap whip set up on this Volvo, in the stock locations. I'm using a Cobra 29LX. The gauge on the radio shows my SWRs to be less then 1 on channel 20. But after a few key mics the screen flashes antenna warning. I'm not sure if I'm evening broadcasting anything I say when I key the mic. I am recieving transmissions from other drivers. I'm thinking about going with like a Wilson 2000 on the driver mirror, but the Volvos don't use the standard 3/8 mount. The coxal has I believe M6X1.0 stud on it. Not sure but I know a 1/4 fine thread is not the same, forgive me since I'm on the road and don't have a thread gauge with me. I did take my mirror driver side mirror apart because I couldn't find the stud when I got the truck, I found the coxal cable had fell from the bracket because there was nothing to hold it to the bracket only the whip. I had to make a road repair so I just got a grade 8 5/16 nut and used it as a spacer then thightened down the whip. Worked for a little while now I get the same antenna warning. So my questions are. Does it sound like a bad antenna,Do I have to run 2 antenna, Will the Wilson 2000 be ok with an out the box 29lx, and would it mount on this Volvo?
  3. rollingradios
    rollingradios Light Load Member
    184
    66
    Mar 9, 2012
    Richmond, Va
    Some of those used both antennas for CB, some the pass side was for FM and driver's side CB. You can go in any truck stop and get the center stud assembly and just replace the whole assembly.
    The plastic washer goes on top. Try this first, then check swr. If still having intermittent issues, try the wilson and set/check swr. If it checks ok then run it.
  4. rollingradios
    184
    66
    Mar 9, 2012
    Richmond, Va
    PS, this top nut is shorter than the one factory. It will NOT come out the top of the mirror shroud, so you will have to feed the antenna through the shroud then screw it into the nut before final install of shroud.
  5. miynis63
    27
    Dec 20, 2011
    Rancho Cucamonga
    RR thanks but I don't think that's going to work. That metric stud come right out of the coxal cable on this truck. It's not a femal coxal cable to thread on to the bottom of the center stud assy. Any other ideas?
  6. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    1st what year and model volvo....?
    most newer volvo's 04 and newer use a multiplex box.(it's mounted under the am/fm radio) to run both sticks, BOTH STICKS are used for tv, cb, radio and if you hook it up also your cell...
    when you did your roadside repair was their a rubber washer on the end of the coax...? it will short out if you don't have it.... and yes you can use willson's on it (thats what i have)
    most of the time when you get a antenna warning the 1st thing to check is LOOK for a small crack in one of the antennas
  7. miynis63
    27
    Dec 20, 2011
    Rancho Cucamonga
    09 670. The driver side wash missing the rubber washer. Road side repair was done on 3/25 worked for a little while. I took that plastic washer and nut from a stud kit and installed it on the stock coxal. It did not help. So then bought a Wilson 1000. Installed on driver side with plastic washer and removed the passenger side antenna. Still got SWR pegged on radio meter. Put the tip of the Wilson all the way in and still high on SWR. So I put the 1 Wilson on the passenger side with tip all the way down and now my SWRs are CH1 less then 1, CH 20 2.2, CH 40 2.2. No more antenna warnings, and I got a copy on a radio check. I don't have a antenna on the driver side now. Are SWR still to high, and is running a single on the passenger side okay?
    Thnx
  8. miynis63
    27
    Dec 20, 2011
    Rancho Cucamonga
    I would rather have an antenna on the driver side, but it just does not work out that way, anything I can use to replace that rubber insulator, to get the antenna on the driver side?
  9. flood
    4,161
    4,031
    Dec 25, 2010
    home depot rubber washer for a faucet should work
  10. miynis63
    27
    Dec 20, 2011
    Rancho Cucamonga
    Antenna warning came back. SWRs on ch20 and ch40 are now up to 2.6, and I don't think im transmitting anymore. The funny thing is I don't get the warning on ch1.
  11. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    It sounds like there is water in your coax cable. If you can not get it down replace the coax cable and make sure when the new one goes in seal the ends with solder heat shrink and hot glue. It could be pinched some where. I would replace it and use plastic armor to protect the coax cable.
