I bought a volvo vlm630 2006 from copart which was badly damaged. I shipped it to my country (republic of georgia). I fixed everything and had to replace the cluster but the used odometer I used to replace the damaged one is showing the wrong numbers. It is also displaying miles instead of the kilometers as well. I was wondering if anyone could tell me what I could use to correct it. I know that the dealer will be able to do this, but I can't send the truck back to the states and there are no dealers that deal with my type of trucks in my country
Thanks
Help with calibrating Odometer
Discussion in 'Volvo Forum' started by giok13, May 11, 2012.
The couple speedometers I dealt with have the code chart in the box on a new replacement.
There are charts on the internet but you need to know the tire size and rear end axle ratio. It should be stamped on the axle housing or in the drivers door jamb spec label.
Post those and I'll see what I can find. Speedometer manufacturer would help also.
There's a few techs online that might be able to help. I think Pablo might be able to help you. He's from over there somewhere.
See if you can't get them numbers. -
I'll get the codes to you soon as I can. In the meanwhile will I be able to reprogram it using vcad or ppt to change the numbers?
Thanks -
Georgia and Georgians) Howdy man, I'm from Ukraine))) LOL
