Help with CAT C15 on Peterbilt 387
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ahmadali04, Jan 13, 2013.
  1. ahmadali04
    ahmadali04 Bobtail Member
    28
    6
    Jan 30, 2011
    I have a CAT C15 Accert on a 2006 Peterbilt 387, and recently when I am climbing a hill, the coolant temperature guage starts to go up and the warning lights and buzzer come on. (It only does it, under a load, going up hills.)
    I just took it to the CAT dealer, and was told, when they hooked up their computer to it, it showed everything was normal, and that engine has never been overheated. Only thing they found was a faulty Barometric sensor, and replaced that.
    Any ideas, on what it could be? Thanks.
  3. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Is the fan kicking in? Maybe thermostats jammed.
    seems strange no logged codes tho, compare the coolant temp in ET to the gauge on the dash.
  4. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    I agree sounds like ar flow problem, is the fan coming on? If so it should be on about 225* and cool it off enough to turn the fan off. Also check for an excessive fuel temp code. If you have the fuel temp wire on it it might have broke a solder joint, if your not using the wire it might have a bad fuel temp sensor, or connection.
  5. seabring
    seabring Road Train Member
    1,844
    1,882
    Apr 24, 2011
    I had the same problems on my 05 w900. If its none of the obvious eg coolant level is good, fan comes on , T stats are good etc it may be that you need a new rad core. That's what I ended up doing. I went with a 4 row core and haven't had any trouble since. A 6 to 7 year old rad has done its job and probably is in need of re-coreing. Just double check the tell tale on the water pump isn't leaking as it would contribute to the problem if it was on its way out.All up it cost me just under three grand for a new core, new stainless pipes and the coolant to fill it , that includes the labour cost as well.
  6. ahmadali04
    28
    6
    Jan 30, 2011
    Fan does kick on. T-stats and water pump were replaced in the last six months. The ECM was showing the engine was not overheating, but the gauge says otherwise...
    Does, the gauge get the coolant temp from the ECM, or there another sensor, for the gauge? Thanks.
  7. Cat sdp
    Cat sdp . .
    21,058
    73,856
    Apr 8, 2012
    Orion's Belt
    I do believe the gauge gets it's info from a sending unit in the top of thermostat housing.
  8. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    heres something else to throw at you, when was the last time the rad/air2air was blown/washed out? if it has a substatial amount of dirt/dust/bugs in it, it wont pull enough air across it when the fan kicks on. we pulled the a/c condensor to the side, pulled air2air off and washed all 3 separately with dawn until it was just water then took a blow gun and blew through them before re-assembling them.
  9. lion tammer
    lion tammer Bobtail Member
    13
    Jan 12, 2013
    San Saba Texas
    i think it could be your radiator ,have you blown r washed it out?
