Help with CB
Discussion in 'CB Radio Forum' started by raverez097, Dec 3, 2012.
  1. raverez097
    raverez097 Light Load Member
    84
    14
    Aug 1, 2011
    Syracuse, ny
    I drive a 2012 Prostar and have a Cobra 29. I replaced the stock antenae with 4and 1/2 Francis. al was fine until recently. The mike was not keying up when pressed unless I played with the wire. And then it would light the ground light on the radio. I replaced the mike and even though it works I still get the red ground light when keyed. I also noticed my SWR on the radio's guage is almost off the chart high. Before it was at about 1.2 on all channels. My thinking is that I messed up the mike connector socket as I kept fiddling with it. Any thoughts?
  3. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    A high SWR indicates a bad antenna ground, bad coax, broken antenna, etc. Check all of those.
    A mic problem does not constitute a high SWR.
  4. raverez097
    84
    14
    Aug 1, 2011
    Syracuse, ny
    It also started the morning after hurricane Sandy. Could too much wind and rain cause a bad ground. I've also lost one of the rubber caps that go on the tip of the antenae
  5. MsJamie
    MsJamie Road Train Member
    Oh, the antenna filling up with water will screw with your SWR...
    Also, bugs have antennae, radios have antennas... :)
  6. raverez097
    84
    14
    Aug 1, 2011
    Syracuse, ny
    Must be a bugs antenae screwing with the radio antenna.... lol
