Help with code
Discussion in 'Volvo Forum' started by Socal Xpress, Aug 19, 2016.
  1. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    I
    2010 D13 723k 10speed
    I have a code Mid 128 PSID 98 FMI 1
    Thats the Boost Air Pressure System.
    I replaced the sensor near the CAC and egr come together but still gettimg this code. Could it be the sensor on the intake manifold itself or do I have another issue.
    Tia
    Reason for edit: More information
  3. Trkr3529
    Trkr3529 Light Load Member
    104
    66
    Feb 14, 2016
    depending on what motor you have I have the D12 and the boost sensor is located on top of the intake manifold
  4. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
  5. Trkr3529
    104
    66
    Feb 14, 2016
    I would assume it's in the same place
  6. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    10 d 13 i believe came with two sensors one on top of cac pipe and one on intake manifold that measures intake temp and the one on top of cac pipe measures boost psi. make sure no leak on connections if code still comes on then need to start checking turbo and egr operation possible one of them is affecting your boost psi.
  7. Val77
    Val77 Light Load Member
    52
    25
    Apr 4, 2016
    You most likely have air leak somewhere on the intake manifold......spray with windex all air pipes- especially around clamps and i hope you find it
  8. Val77
    52
    25
    Apr 4, 2016
    Here you go
  9. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    You replaced the turbo recently? Probably not the sensors but something else. Start at the beginning unfortunately and work your way from there. I had the same thing a little while ago and it was a clamp that came a little loose. I assume that you checked all that so it could be a leak from when the repair was done and it came loose or a pin hole developed. Grunt work and very time consuming to find.
  10. prosco
    prosco Bobtail Member
    I need help!!!
    My 2009 volvo VNL630 with Cummins engine, shows check engine fault , the computer report is flash code 1881 and lockup code SID 324.
    I clean the filter a lot a time and the check engine light again. What can I do?
  11. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Before you look at sensors, you need to look at the mechanicals. Check for leaks.
