Help with dyno
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Youngtrucker91, Mar 1, 2019.
  1. Youngtrucker91
    Youngtrucker91 Light Load Member
    152
    49
    Aug 11, 2015
    Was this a good dyno
  3. 806 man
    806 man Bobtail Member
    11
    8
    Feb 9, 2019
    Yes, Not sure how you run the engine, however, Your highest torque and HP was at 1380-1400 rpm range with good boost. which is the sweet spot for fuel savings.
  4. Youngtrucker91
    152
    49
    Aug 11, 2015
    Thanks for your response what about blow by
  5. 806 man
    11
    8
    Feb 9, 2019
    Blow by was fine once under a load. If you have concerns pull an oil sample after 8-10k miles to give you a better understanding about the internal wear parts/points or antifreeze issues
  6. Youngtrucker91
    152
    49
    Aug 11, 2015
    Opinion on this one
  7. 806 man
    11
    8
    Feb 9, 2019
    Well I hope you didn't pay for that one. 5000 ft torque with under 400 hp. Not happening. Did you pay for that? The tech should have said WTH is wrong
  8. Youngtrucker91
    152
    49
    Aug 11, 2015
    Nope they did the dyno saw it was really low hp only 365hp on dd15 not right
  9. 806 man
    11
    8
    Feb 9, 2019
    How did they explain the high torque rise?
  10. Youngtrucker91
    152
    49
    Aug 11, 2015
    No they didn’t on the web site shows that the dealer did the dyno come to find out prime did the dyno not the freightliner dealer I’m just going to have it re dyno just to make sure
