help with engine model info
Discussion in 'Trucks [ Eighteen Wheelers ]' started by joecitizen, Jul 10, 2013.
  1. joecitizen
    joecitizen Light Load Member
    242
    38
    Mar 15, 2009
    Tucson, AZ
    i have been looking at used trucks and came across this for the engine model: C15'02 435/2100
    i know what C15 & 435/2100 means, but i dont know what C15'02 means...
    truck is a '07 9400
    thx
  3. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,045
    May 13, 2011
    Middle Tennessee
    "but i dont know what C15'02 means"
    C stands for Carbon and it means it puts out a 15 foot trail of carbon per 2 seconds at highway speed. It is a CARB rating.
    BTW I have some mountaintop real estate for sale in central Indiana if you're interested. :biggrin_2559:
  4. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    Y do I always seem to read those comments right after I have taken a drink? I NOW blame YOU for having iced tea all over myself lol.
  5. Ruthless
    Ruthless Road Train Member
    9,089
    90,135
    Aug 28, 2010
    The City.
    Might be its a glider with a 2002 c15 motor in it
    cetanediesel Thanks this.
  6. joecitizen
    242
    38
    Mar 15, 2009
    Tucson, AZ
  7. dirthaller
    dirthaller Road Train Member
    1,109
    12,963
    Sep 22, 2011
    Coloratah
    If its an 02 it will have a 6NZ ser# If its an 07 It will have a MXS or NXS ser#
    joecitizen Thanks this.
  8. joecitizen
    242
    38
    Mar 15, 2009
    Tucson, AZ
    @dirthaller...this particular truck is a 2007 International 9400, but i have seen it on other makes also. should i be understanding you correctly, even though the model year of the truck is a 2007, the engine is possibly a 2002. the only way to tell is for sure is by the vin as u stated above. not sure if truck is a glider, highly doubt it.
    i have also seen C15'04, which i presume is indicating a 2004 engine in a 2007 model year truck?
  9. dirthaller
    1,109
    12,963
    Sep 22, 2011
    Coloratah
    The 04 EPA engines were used from Oct 2002 to Jan 2008. The 07 EPA Engines were used from Jan 2008 till Jan 2012 The model year of engine should be on the oil cooler under the turbo. If your trying to be CARB compliant, you will need a 2008 model truck with a 2007 EPA engine.
  10. dirthaller
    1,109
    12,963
    Sep 22, 2011
    Coloratah
    BTW the C15 that is CARB compliant has a SDP ser# and they are problematic.
  11. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    The sdp is a good motor if you get rid of the epa crap.
