Anybody out there know where the fuse is for the wiper pump on a 97 freightliner century my pump isnt working I gave it direct power and it does work but I can't find the fuse for it I already looked at the fuse box on the passenger side and behind the driver side door I called freightliner but there computers are down
So if anyone could help me out I would appreciate it
Help with fuse location
Discussion in 'Trucks [ Eighteen Wheelers ]' started by chubbz817, Jan 1, 2012.
I think there is a fuse box next to the driver seat also.Helped a friend find why his sleeper lights would'nt work,that's where the blown fuse was.
Yea I already checked there
How funny, calls the repair shop and they can't help you cuzz the freakin computer is down, please don't ask me my opinion on these so called ase certifed monkeys, for the op get a test light znd start following the wire back, once you.find the place that makes the light come on change what ever is between the dead wire and live wire, its really that easy.
Yea to bad the it goes behind the motor and goes into the cab into the dash that's y I asked maybe someone would have some insight
If only I was there, well heres something else to try, using a test ligjt go and make sure all the fusrs get power to both sides, sometimes they use a fuse thats for spmething else. Just a thought
Maybe it's hooked up to the radio and the radio dial has to be set at CISN 103.9 in order for the washers to work.
http://www.cisnfm.com/ -
Isn't the fuse panel on the dash in front of the passenger seat?
Have you checked the glove box?
No I didn't kno I had any up there are they behind the material ? I looked and dnt see anything
