Hey, I need help. I have an 09 international ProStar premium. With cummins 435hp and the ratio is 2.64.. When I drive 65mph the RPM is a lil over 1500 and I don't get good MPG.. And when I drive with RPM between 1100-1300 I save 2.6mile a gallon.
What's the way to lower RPM and keep my speed 65mph? Is that possible?
One of drivers told me to change the ratio is that right?
2nd Q
What's the wheel base ? I see it a lot on truck paper magazines?
3rd Q
Is any way I could do to give my truck the power to go up hill? Cause when I go up hill my truck is not has the power I need?
Help with my truck..Please
Discussion in 'Ask An Owner Operator' started by milad, Jun 13, 2015.
Page 1 of 7
Look on the sticker in door jam to see the ratio
RPM doesn't save fuel.....speed does
CK. the air ride leveling valve to be sure its not jacking your rear/ends up when you stop then its taking too long to let air back out to level it out so wheels wont spin when you start from a stop?
blairandgretchen Thanks this. -
You can change your gear ratio and that can improve your mpg. I used to run an International with 354 gears and I averaged 6.29 mpg. It had good pulling power with that gearing. You first need to find out your current gearing.
What was HP of your engine ? And what manufacturing?
Does it effect if it's different engine manufacturer? -
I ran a CAT 3406 engine with 445 hp on the ground with a Spicer 10 speed transmission. Some people say that CAT doesn't do as well as Detroit or Cummins when it comes to fuel mileage. I always got good fuel economy with CAT engines. Your driving habits will affect your mpg more than any other single factor. I mostly drive at or under 65 mpg, but would run that truck around 70 when I ran out west. I used to run Detroit engines, but got better fuel mileage with CAT. I still run CAT, but average 7 mpg or a little more with the truck I drive now. I keep my speed down and usually drive at 65 mph or less and I do more deadheading that I did at one time.
Page 1 of 7
