Help with peterbilt wiring.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cowtrkr22, Feb 4, 2013.
  1. Cowtrkr22
    Cowtrkr22 Bobtail Member
    So I recently replaced the wiring harness in my 1993 379. almost everything works as it should except for a few gauges I think I hooked up wrong and the jake. My problem is with the jake tho. The peterbilt wiring schematic shows 5 wires at the switch on the dash but only 3 are needed. I found the three wires and hooked them up... Nothing. there are four prongs on the back of the switch, and there were only 3 wires hooked to the old switch when I took it apart. the wires I have are 225 224 and 223. where the hell do they go on the switch. I could have put more time into switching them around 40 times until I maybe got it to work but I assumed it would be easier just to get on here and ask. can anyone help? I also need interior upholstery and molding for my 93 with a non unibilt. the bunk upholstery is fine the cab is all that burnt. anyone have anything laying around. thanks!
  3. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    www.supermiller.com
    Good site with lots of Petercar info. Go to right side of home page and hit the schematic drop down box. Hopefully you will find something to help you...:biggrin_25514:
