speedometer was spiking so I replaced the speedo pick up and now no speedometer at all and the auto-shift does not work right. 2001 kw t-600 with eaton 18 spd auto-shift. when it shifts there is no throttle response for approx. 3 seconds. the trans shows no active or inactive codes. have ripped the wire harness down to the ecm.... can find nothing wrong and it all ohms out found test to check pick up and its working. put test ecm on and no difference.... does anyone have any thoughts on this thing????
help with speedometer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by beagle01, Oct 20, 2015.
Is this a screw in sensor or the 1 bolt type? Speedo spiking up and down can just be a loose tranny yoke nut.
^^^^ 2nd this.
Is this a magnetic pickup style speed sensor? If so did you adjust the new one correctly when you installed it? Too much gap between the sensor and the tone ring would cause it not to pick up a signal. The typical adjustment is to thread it in until it contacts the tone ring, then back it out about half a turn. As long as it doesn't contact the tone ring when the driveshaft is spinning it should be ok. The service manual should have the exact spec and you should be able to download a pdf version of it right off Eaton's website. -
has both type sensors. both have been replaced. and the screw in one has been set anywhere from 1/8 turn to 2/3 turn out after contact. Have tested the screw in one with a multi meter and it has continuity from one end to the other. also did an a/c test and it is picking up and creating the proper signal to the ECM, yet, the ECM says it is getting no signal... have had 3 different ECMs on this truck to test and none of them make a difference.
I've never seen a tail shaft housing with 2 different sensors before, that odd. I've seen some with 2 sensors, but not mixed with 1 screw and 1 push in. Anyway, I suspect that your whole issue from the beginning is a wiring issue. I'd also suspect that it is close to the tail shaft, probably over the transmission, because that would be where you would have moved wires when changing the sensor. Ohm out the sensor, then remove the OEM plug on the ECM and ohm out those pins, it should be very close. If it's open or a very high resistance, then you have a wiring issue. Sometimes you can find it easy if you have someone else wiggle the wiring while your watching the meter. If you get changes when you wiggle, you in there area. That usually works if it's got a connection with high resistance, not so much with an open circuit.
i have done all of that. it is a auto shift trans. one sensor goes to the Eaton side and one goes to the kw side. i have had the wiring harness completely apart and looked at all wires and connections. i have ohmed from one end to the other there is no wire issue. I came in 2 weeks ago to put a new front suspension in this truck. the speed o had been spiking at times so i replaced the screw in speed o pick up and lost all speed o function and no throttle response when trans shifts
Just out of stupid curiosity how is your volts ? I have seen a bad alt cause all of this and changed the sesnors thinking it was that. Instead it was the alt going bad and causing spikes and malfunctions thur the system. Just a thought.
There has got to be something that you missed. You've ruled out the ECM, so the only things left are the sensors, the wiring, proper gap and tone ring. I have never seen a tone ring fail on a transmission, only spin from a loose yoke. What codes are you getting? Any codes in the trans?
You're sure the new one is the correct part #? Did you try to put the old one back in? Sometimes new parts are bad. If it's putting out an A/C voltage then it's probably good, but I don't know the specs, it could be a signal that is too weak.Last edited: Oct 21, 2015
OK guys,
I took belts off of alternator and unhooked the wires..... no change...I took all ground wires off, cleaned them and re installed them....including all battery cables... no change....I have positioned the truck so that I do not have to drive it down the road.... this allowed me to remove the speedometer pick up and observe the tone ring turning...removed drive line and tightened to make sure was not slipping .... have replaced both pick ups 2 times to rule out bad ones..... took a speed o pick up out of a truck that works fine and installed it..... no change... I have removed all wire harnesses from pick up to Ecm I inspected and had someone else inspect and still nothing.... by the time this gets figured out..... I'll be bankrupt .... been working on this for 11 days straight -
I know trying to do things frugally sounds great but after 11 days, I would have lost more money than the truck was worth and have had my truck down for a month on things that could have taken a day or less so I stopped trying to figure things out and go to the dealer now with all the trucks.
