Help with Studio Sleeper curtains
Discussion in 'Kenworth Forum' started by RubyEagle, Aug 25, 2016.
  1. RubyEagle
    RubyEagle Medium Load Member
    632
    788
    Apr 17, 2010
    Had a company Columbia then a Cascadia. Had an '05 Volvo then sold it to get this beautiful Kenworth. The curtains are great in those trucks.
    Can some one help l am very slow adult apparently since l cannot figure out the sleeper curtains in this Studio.
    It seems like they just aren't long enough to close together. I have tried moving the front seats up with armrests in down position and no luck. I pulled the off the low side track snap buttons on each side still no luck. I can get the Velcro at the bottom to touch but that's it.
    Tried searching this site and Google no luck. I can't be the only one that has had this issue. Thanks in advance.
  3. larry2903
    larry2903 Heavy Load Member
    788
    988
    Oct 18, 2009
    On the trails
    Each side of the curtain has an elastic strap wit a loop at the end that hangs from a hook between the upper front sleeper windows. If you attach those straps first then you'll be able to zip up the curtains, hard to zip them up if you don't do this first.
    RubyEagle and crb Thank this.
  4. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    Curtains are hard to zip but they should zip up.
    RubyEagle Thanks this.
