Help with waterpump replacement on acert
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SimD, Dec 27, 2012.
  1. SimD
    SimD Light Load Member
    148
    30
    Dec 23, 2012
    dallas, tx
    Anyone have instructions on how to remove water pump on c15 acert. And plz don't say unscrew stuff and remember how it goes back.
  3. e500gvr
    e500gvr Light Load Member
    125
    32
    Aug 21, 2006
    Bloomington,MN
    [TABLE]
    [TR]
    [TD="width: 386"][FONT=Geneva,Verdana,Tahoma,Arial,Helvetica,Sans-serif]Product: [/FONT][FONT=Geneva,Verdana,Tahoma,Arial,Helvetica,Sans-serif]TRUCK ENGINE [/FONT][/TD]
    [/TR]
    [TR]
    [TD="width: 14"][/TD]
    [TD="width: 386"][FONT=Geneva,Verdana,Tahoma,Arial,Helvetica,Sans-serif]Model: [/FONT][FONT=Geneva,Verdana,Tahoma,Arial,Helvetica,Sans-serif]C15 TRUCK ENGINE NXS [/FONT][/TD]
    [/TR]
    [TR]
    [TD="width: 386"][FONT=Geneva,Verdana,Tahoma,Arial,Helvetica,Sans-serif]Configuration: [/FONT][FONT=Geneva,Verdana,Tahoma,Arial,Helvetica,Sans-serif]C15 On-Highway Truck NXS00001-UP [/FONT][/TD]
    [/TR]
    [/TABLE]
    [FONT=Geneva,Verdana,Tahoma,Arial,Helvetica,Sans-serif]Disassembly and Assembly[/FONT] [FONT=Geneva,Verdana,Tahoma,Arial,Helvetica,Sans-serif]
    C15 On-highway Engines
    [/FONT] [TABLE]
    [TR]
    [TD="align: left"][FONT=Geneva,Verdana,Tahoma,Arial,Helvetica,Sans-serif]Media Number -RENR9403-11 [/FONT][/TD]
    [TD][FONT=Geneva,Verdana,Tahoma,Arial,Helvetica,Sans-serif]Publication Date -2010/03/01 [/FONT][/TD]
    [TD="align: right"][FONT=Geneva,Verdana,Tahoma,Arial,Helvetica,Sans-serif]Date Updated -2010/03/18 [/FONT][/TD]
    [/TR]
    [/TABLE]
    [TABLE]
    [TR]
    [TD="align: left"] [/TD]
    [TD] [/TD]
    i02852243
    [/FONT][/TD]
    [/TR]
    [/TABLE]
    [h=2]Water Pump - Remove[/h]SMCS - 1361-011
    [h=2]Removal Procedure[/h]
    Start By:
    1. Remove the precooler. Refer to Disassembly and Assembly, "Precooler - Remove".
    [TABLE]
    [TR]
    [TD][HR][/HR][/TD]
    [/TR]
    [TR]
    [TH][SIZE=+1]NOTICE[/SIZE][/TH]
    [/TR]
    [TR]
    [TD]
    Keep all parts clean from contaminants. Contaminants may cause rapid wear and shortened component life.
    [/TD]
    [/TR]
    [TR]
    [TD][HR][/HR][/TD]
    [/TR]
    [/TABLE]
    1. [TABLE]
      [TR]
      [TD="colspan: 2"][HR][/HR][/TD]
      [/TR]
      [TR]
      [TD="colspan: 2"][​IMG]
      [/TD]
      [/TR]
      [TR]
      [/TR]
      [TR]
      [TD="align: left"][SIZE=-1]Illustration 1[/SIZE][/TD]
      [TD="align: right"][SIZE=-1]g01080189[/SIZE][/TD]
      [/TR]
      [/TABLE]
    2. Remove bolts (1) . Remove support (2) .
    1. Loosen hose (3) . Slide hose (3) downward onto water pump cover (4) .
    1. Remove bolts (11) . Remove oil cooler bonnet (10) from the engine oil cooler. Remove integral seal (8) and O-ring seal (9) from the oil cooler bonnet.
    1. Note: Hose (3) will be removed with water pump cover (4) .
    2. Remove bolts (7) . Remove water pump cover (4) from water pump (5) . Remove the O-ring seal from the water pump cover.
    1. Remove bolts (6) .
    1. Remove water pump (5) from the front housing.
    SimD Thanks this.
  4. oneshot
    oneshot Medium Load Member
    626
    248
    Feb 28, 2009
    mississippi
    So basically u take stuff loose and remember how it goes back, according to CAT.:biggrin_25523:
  5. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    unless they changed it since I checked last, cat warranty pays 6 hours to r&r waterpump, its been a couple years since I did 1 or looked at 1, been working on dd15 and isx. drain coolant, remove air cleaner piping, take front bellow off turbos along with front housing of lower turbo, remove precooler, coolant divertor and cooler bracket, oil cooler water neck, lower radiator hose, take backside cover off water pump, then remove bolts from frontside of front cover, remove water pump. you will have to fanagle, yes this is a mechanic word, the back cover and water pump out, put some white lithium grease or dielectric grease on the new o-ring on the water pump and dont pinch the oring when you go in with the new pump. hope this helps, there may be another step or two as it has been a couple years since I did 1 but this should be the basics. if you are not mechanically inclined it can be a job. I use to be able to do these in about 2 hours in my shop with all the tools at my disposal, but I've done hundreds of them.
  6. SimD
    148
    30
    Dec 23, 2012
    dallas, tx
    Thank you so much guys
  7. believe456
    believe456 Light Load Member
    191
    22
    Apr 22, 2015
    Why can’t i see these pics?
  8. MAMservices
    MAMservices Medium Load Member
    556
    3,997
    Aug 9, 2021
    May be because they are over 9.5 years old? Maybe?
    AModelCat Thanks this.
  9. believe456
    191
    22
    Apr 22, 2015
    That means pictures disappear. What happened to what goes on the internet is there forever. But you didn’t have to be negative
