HELP
Discussion in 'Trucks [ Eighteen Wheelers ]' started by seapup, Feb 7, 2011.
  1. seapup
    seapup Light Load Member
    88
    15
    Aug 1, 2010
    wodstown,nj
    I have a 93 freightliner with an n-14 engine. I am sitting at a rest stop now and desperatly need help. The truck was running fine until this evening. Now it stalls whenever I come to a stop and attampt to take off. I have to wait for about 1/2 hour then it will start and take off ok. It will run down the road fine until I have to stop again be it 5 minutes or 2 hours. When I stop it will idle but as soon as I give it some fuel it dies. Whats going on?
  3. seapup
    88
    15
    Aug 1, 2010
    wodstown,nj
    Additional info. I had a shop replace a leaking gasket on the fuel pump about 2 weeks ago. Is it possible that could be causing this problem. Also I checked the codes, nothing showing.
  4. seapup
    88
    15
    Aug 1, 2010
    wodstown,nj
    More info. Checked and topped off coolant level. I am now going to clean battery terminals.
  5. rocknroll nik
    rocknroll nik High Risk Load Member
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    hows your fuel filter.....
  6. seapup
    88
    15
    Aug 1, 2010
    wodstown,nj
    Fuel filter was replaced 2 weeks ago. Just checked codes again after cleaning battery cables and I am getting code 121 engine position sensor circuit. What is that?
  7. rocknroll nik
    4,490
    5,770
    Oct 18, 2008
    can't read the sign
    not sure man....have you tried a freightliner website?
  8. logtrucker25
    logtrucker25 Light Load Member
    70
    9
    Jul 27, 2009
    northern CA
    could be crank or cam sensor maybe? search the board theres gotta be a code list somewhere...
  9. Heavyd
    Heavyd Road Train Member
    7,815
    6,268
    Feb 4, 2009
    There is only the engine position sensor. It is located just below the compressor drive and above the oil pump on the front left side of the engine. There is a connector about 4 inches back from the sensor. Make sure it is fully connected and the terminals inside aren't corroded. These sensors won't last forever. Sounds like the sensor has a partial short/open coil and it can't generate a proper signal at lower rpms.
  10. seapup
    88
    15
    Aug 1, 2010
    wodstown,nj
    more info. When I pull the codes I get 222. I know what that is and have had it for 6 months with no effect on the running. Now when the engine stalls and I try to restart it the check engine light flashes 121 code. But then when I pull the codes again it just gives me the 222. I'm lost.
  11. QUALITYTRUCK
    1,817
    1,783
    Jun 14, 2009
    romulus,mi
    you have to change e.p.s.(engine position sensor)when you remove it chances are there will be a hole in middle of sensor letting oi leak through.cummins part #4984223.pain in the ##### to remove sometimes.good luck!
    rocknroll nik Thanks this.
