hello guys... im thinking of swapping my series60 to a 475 3406e cat..i was getting over 6.0mpg before i stretched the hell out of it..when i did that,all the lil power i had (poof) was gone.i put a program to the ecm to raise the hp to 575hp with 1850lbs of torque, everything went back to normal. now im doing 5.4 runing at 65-67.....my current set up its 575 detroit 12.7,9spd,3.70 rears..what dou u guys think, should i change my rears to 3.55 or change the motor and rears???? btw i do produce between miami fl and md,pa,nj and always 80.000lbs
HELP
Discussion in 'Ask An Owner Operator' started by jander, Apr 4, 2014.
I would start with the rears before the motor.....3:55 or 3:42 and I bet you will see an improvement, might suffer some in the hills up north though. That Detroit is notorious for good fuel mileage. Although I like Cat, I don't think you will see much improvement in fuel mileage by switching motors. Just my opinion. Oh, you might want to convert that 9sp to a 13.
cabwrecker and chalupa Thank this. -
soo i guess 13 spd and 3.42 or 3.55 it is.....cuz im im riding at 1500 rpms at 64 and its killing me....i dont mind 67 or 68 but not 64
Gotta second (or third) the 13spd. Going with that should help you out right away with both pulling hills and a bump up in mpg.
11R22.5's or lopro 24.5's same overall diameter would be the right tires for those 3:70 rears. I would not have lopro 22.5 on a truck set up like yours. It would put you about 68mph @ 1500 rpms. 11R24.5 would drop rpms even more.
