HELP!!!!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mirsadvic, May 1, 2015.
  1. mirsadvic
    mirsadvic Light Load Member
    70
    5
    Dec 23, 2013
    Morning, im crusin down i 95 and the truck just shuts down no poer no contact at all? Steering locks up barely made it over any idea whats going on before servixe rips me a new one ?
  3. unloader
    unloader Road Train Member
    1,037
    1,156
    Jan 7, 2013
    You got fuel in the tanks?
    unloader
  4. mirsadvic
    70
    5
    Dec 23, 2013
    Yep the truck just shut down it has no contact at all
  5. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    ecm fuse ran out of fuel cloged filter
  6. Diesel Dave
    9,319
    30,014
    Jan 20, 2010
    Hesperia, Ca.
    You need to elaborate more info, truck, engine, etc. Did you get a check engine light on or warning prior to shut down? The first things to check all electrical connections starting from the battery and work yourself up from there.
  7. mirsadvic
    70
    5
    Dec 23, 2013
    I got a engine fault before it happend 09 780 cumins engine. The dash is froze on 55mph and temp shows as it was when it was on
  8. mirsadvic
    70
    5
    Dec 23, 2013
    I have no eletrical power what so ever i do hear a click clic click other then that nothing
  9. mirsadvic
    70
    5
    Dec 23, 2013
    Were is the ecm fuse in 09 780 cumins
  10. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Should be in the battery box
  11. mirsadvic
    70
    5
    Dec 23, 2013
    Any idea what amp fuse should be in there 109? 250? 400?
