Help?
Discussion in 'Experienced Truckers' Advice' started by JuanchoJUAN89, Feb 12, 2017.
  1. JuanchoJUAN89
    JuanchoJUAN89 Bobtail Member
    Hello everyone. I've been driving for over 3 years now and I got some money to buy at least 2 good used trucks to start my own business. I'm from FL. I'm thinking about putting those two trucks to work for a company. They said they provide all the permits, IFTA, plates, insurance and that stuffs. They take 20% from each load plus I have to pay about $720 a month for the trailers... is it a good deal?
    I want to put 2 drivers to each truck and send them to do OTR.
    What should I do? What type of company would you guys recommend close to Sunrise, FL. For a new owner operator and what's the average a owner operator should get per mile?
    Thanks a lot for any advice I can get in here.
  3. Byx
    Byx Light Load Member
    150
    225
    I think you need to do a lot more research man. The owner op forum is a good place to start, but I think with 20% off the load to start, you're going to be running real lean already. And you'll want to profit on top of that. The checks your driver's will pull won't be very appealing
  4. Brandt
    Brandt Road Train Member
    4,612
    6,332
    Sep 17, 2012
    Google the rule of 72. If you want to make money and not any work, just think about that.
    If you have $20,000 you can double that in 7 years to 40k. Then 7 more year you double the 40k to 80k. 7 more years you double 80k to 160k. See now you making money at 21 years in. Now the rule of 72 is really making money you money. 160k will double to $320,000 at 28 years in. Want to go 7 more year to 35 year your $320,000 become $640,000. Let's go 7 more year or 42 years in the future your $640,000 will double to $1,280,000. That's how you turn $20,000 into $1,280,000. Just something to think about vs buying two used trucks a hoping you make money.
  5. Ridgeline
    22,649
    120,845
    I recommend you keep driving and forget about it. Unless you've been saving a lot of money and you've been doing research on how this all works, you've got a long way to go.
  6. superTrucker77
    superTrucker77 Light Load Member
    75
    15
    Feb 11, 2017
    Not the best time to do it now, the used trucks got to be pre-emissions trucks engine maid before 04 to be reliable, besides the truck you need drivers you have some one on the list that will be willing to get in to your used truck instead of getting in new truck with someone known as successful in the business? Will you afford to take a lost for few months and continue to pay your driver on time? 20% is way to high for the dispatch and the autority, independent dispatchers charge you 10% of the gross, plus plates and ifta, plates around 2000 ifta around 200 a quarter. With e-logs coming up, no one knows what will happen to the guy that run their own trucks not under big fleets, going under a mega carrier you hardly will make living if you drive yourself a used truck if will at all depends on your luck with the truck. Concider getting one truck find a good dispatcher (independent ) get your own trailer, get in that truck and drive to start with, learn the business and see to yourself if you will be able to put the other truck on the road and have anything left after paying the miles or time to the driver.
  7. scythe08
    scythe08 Road Train Member
    2,879
    3,764
    Mar 19, 2007
    Portland, Or
    Dude, you aren't ready to run your own truck, and I say that respectfully.
    You have to already have a game plan before you even think about buying a truck. You have to know you're cost of operation down to the penny, or how do you know what it takes to be profitable, let alone what you can pay a driver.
    Also the trailer rental is more than a used trailer rental, IMO, unless it's a specialty trailer.
    You need to do some serious research
    street beater Thanks this.
  8. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    This x2
    Its not being mean to say, you should know right away if it will be profitable. You want to run a 5 year plan down to the penny. If you want to run just one truck, monthly note on the truck, fuel cost, (assume max miles) pm service costs, where and how offen? How much? Trailer rent cost, if your running teams, your looking at what, 50c a mile to the drivers split, thats probably low. (Im not a owner) tires? Who pays upkeep on the trailer? What if it goes down? Insurance, taxs... the list is friggin huge.
    scythe08 Thanks this.
  9. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    So many things to consider, but the thing that breaks most "truck owners" is
    • "bad and/or undependable and/or thieving drivers"
    • Freight [rate] downturns that last months or more
    • Getting burned by bad brokers while you're developing your reputation
    • Major breakdowns and towing
    No way to put a cost on either of these. Maybe they happen early on, maybe they happen just when you think things are going good, but they will happen. The only question is does it break you, or does it make you wonder WTH were you thinking, I'm done, or was it just a very costly learning experience?
    Texas_hwy_287 Thanks this.
