Help!
Discussion in 'CB Radio Forum' started by rbrtwbstr, Mar 13, 2017.
  1. rbrtwbstr
    rbrtwbstr Road Train Member
    3,394
    7,892
    Jul 11, 2012
    in the bush somewhere
    Ok I know this is somewhat of a Ford vs Chevy type of question, but I'm nearly illiterate when it comes to CB's. So if y'all could maybe help me it would be much appreciated.
    I'm getting a new truck next month, and I want a good CB in it. I've been using a stock Cobra 29 and just a cheap Fire stick antenna. It serves the purpose just fine, but it stays with my current truck.
    So I've been looking at radios and I'm lost. I was thinking a Connex 3300, and maybe a Wilson 2000 antenna. I don't need it to blow anyone's eardrums out, and I don't need all the TalkBack, echo, noise toys, or anything of that nature. Just a good CB that does the job a little better than my current setup.
    Any suggestions?
    Edit: does anybody make a CB guide for idiots? I could use one of them too
  3. Ridgeline
    22,658
    120,980
    Get another cobra. Something simple and without the bells and crap.
  4. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    How much you willing to spend? In all honesty. To get the biggest Bang for your buck, and make a noticeable difference that people will notice, Just keep what you got and stick a 2-pill Amp behind it...(may need to upgrade your antenna if the one you have can't handle the watts)
    rbrtwbstr Thanks this.
  5. rbrtwbstr
    3,394
    7,892
    Jul 11, 2012
    I'd like to be in the $250-300 range for the whole deal
  6. wolverine11
    wolverine11 Road Train Member
    1,629
    1,234
    Apr 1, 2015
    I agree with ridgeline you cant go wrong with a Cobra 29 but if you did want to get a dual final radio in a compact chassis without all the bells and whitles look at the new Galaxy 55 F, they have about 40 to 50 watts pep and retail for about $ 200.00, will you notice much difference in transmit and receive over the single final 29, thats for you to decide.
  7. SpaceMann
    SpaceMann Bobtail Member
    18
    7
    Mar 8, 2017
  8. HotRodConner12
    HotRodConner12 Bobtail Member
    18
    15
    Jan 3, 2017
    NW Georgia
    Galaxy radios are definitely worth taking a look at. I own two and can't complain. First one was given to me, a DX919, had freq. aligned and peaked to about 20 watts. I then upgraded to the old style DX44V. It was traded from a friend. It didn't work at the time so i went and had it fixed at the local CB shop. $80 later i was pushing 40 watts with aligned freq, and everything works correctly on the radio. I then upgraded my antenna to a 5' firestik, mounted above my drivers side tail light(Ford Ranger), with firestik hardware and heavy duty spring. 21' RG8X coax and i have radio wired to battery with a 5amp fuse. I have SWR 1.1 on ch. 1 and 1.2ish on ch. 40. I talk on SSB a lot, (26.885mhz) and i reach out 25+miles. I recommend galaxy radios and I've never had any problems out of the firestik. Cant complain, it holds up just fine at 60-65mph. I would like to test this antenna's bandwidth, since i can reach 10 meter and CB band with my 44. My only other thing i plan to add is to have a Texas Star 500 watt. I'll also upgrade to stainless steel antenna cause the 5' firestik is capable of 1000 watts but i know the performance and reception will be better with a whip.
