Help!!!
Discussion in 'CB Radio Forum' started by Daddynicky, Apr 16, 2018.
  1. Daddynicky
    Daddynicky Bobtail Member
    Apr 16, 2018
    Kansas City
    Ok so I’m new to this site and very new to the cb radio. My pops has been driving for 30+ years and I have been local for 10yrs but I haven’t done anything with a cb. So I bought 2 4ft fire sticks which for what I want will work perfect. I bought a cobra 29nw Ltd classic and an swr meter. Now I am tuned to the point where I am 1:1 and I’m not sure if either truckers just don’t talk much in my area which is Kansas City or if I have something screwed up. If someone could help me that has experience but at the same time could explain it to me in ####### terms I would greatly appreciate it
  3. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,209
    Oct 25, 2015
    Fort Worth
    Squelch fully open (left)
    Gain fully open (right)
    On “CB” not “PA”
    Mike gain (Dynamike) full right
    Etc. Per manual (see also website CBRadioMagazine for review of your unit)
    Should be able to “hear”. Transmit can be more of a problem.
    Does the built-in speaker work? (Static noise changes when adjusting RF Gain or Squelch)
    Does keying the mike cause a change in what’s heard (cuts off sounds)?
    Antennas are mounted in a fashion as you see others do on a big truck? Coaxial cable without damage as you can see it? Not pinched or torn; terminations aren’t loose; coming off.
    Can you borrow a known working Radio to substitute? Only takes a moment.
    rabbiporkchop Thanks this.
  4. cleanrf
    cleanrf Bobtail Member
    11
    Jul 19, 2018
    Did you get this worked out?
  5. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    The ability to transmit should be directly proportional to the ability to hear something so as one increases the other should also increase.
