Hendricson Airtek front informaton?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Oram, Sep 29, 2012.
  1. Oram
    Oram Medium Load Member
    452
    199
    Jan 28, 2012
    WINDSOR, ON, CANADA
    I am very-very tired of the cement highways, broken, fixed, all. I want my next truck with the best possible ride. One of the two truck what I am considering is a Cascadia with Hendricson's Airtek suspension. I would greatly appreciate any information on it.
  3. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Get it, you will enjoy it. Sure, it will feel different and probably sway a little more, but once you adapt you won't notice. Your tire life will also greatly increase too.
  4. Oram
    452
    199
    Jan 28, 2012
    WINDSOR, ON, CANADA
    Thank you. This is what I think, I just would like to hear from people who use it.
  5. freightlinerman
    1,287
    536
    Mar 4, 2011
    Florida
    Spring suspension is old and outdated, as are drum brakes. Get with the times.
  6. Oram
    452
    199
    Jan 28, 2012
    WINDSOR, ON, CANADA
    Yeah. But I do not want to be the guinea pig either. The disc brake is still expensive, has problems, and the parts are not available everywhere yet. The improvement over the high performance drums are not so big, so I will not get it at this time. Probably next time.
  7. wichris
    wichris Road Train Member
    4,276
    8,602
    Jan 17, 2011
    I've used airtech for almost ten(model) years. Early ones with only one leveling valve were a pain for ride height. Drivers loved them,took the road shock out of the front. No alignment problems,even if you lose an airbag you can drive it in. Have disc's on the 2011,12,13's and only had to replace one set of pads. If the dealer works it right there is no additional cost for them.(KW & FL) Trailers are still up around 2k extra but still worth it. Run them in the mountains(T&T)and you won't ever go back. Get DOT'd and they roll under the truck and right back out,nothing to measure.
  8. freightlinerman
    1,287
    536
    Mar 4, 2011
    Florida
    I've got news for you. Disc brakes are standard equipment, it is a requirement for all 2012 trucks. There are no more drum brakes. Disc brakes will outlast drum brakes. The stopping distance is remarkable. Look on youtube for Bendix disc air brakes. http://www.youtube.com/watch?v=v57K1WW41K8
    There is the video. The distance it saves WILL SAVE you an accident, life, limb or injury one day, maybe even your job. The first test it saves 65 feet compared to drum brakes, that's almost the length of a tractor trailer combo. Watch the video further. You will change your mind about disc brakes, I'm serious. Watch the video and then tell me what you think of disc brakes and that they "don't stop that much" better.
    Don't forget! The difference when drum and disc brakes heat up, which stops better? Which stops at all?
    Heavyd Thanks this.
  9. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    I got my 07 Century with an Airtek.
    Your kingpin is an actual part of the axle. If they go bad, it's an additional $1500 to the repair. You have to replace the complete axle, not just the kingpin and bushings. Kingpin bushings just cost me $1000 to have repaired. I scrubbed off a set of steers in no time with bad bushings. Those were another $980.
    Airride fronts sway a lot more. I almost wish there were an anti-sway bar on the front like on cars/pickups. You will notice in a heavy cross wind it feels like you are leaning. You can see it in the mirror on the truck to trailer line.
    Oram Thanks this.
  10. wichris
    4,276
    8,602
    Jan 17, 2011
    Do you have dual leveling valves? Single valves were bad for that.
  11. MNdriver
    7,985
    4,372
    Feb 24, 2012
    Just a single. May look at putting a second on
