HEST indicator
Discussion in 'Ask An Owner Operator' started by kw600, Dec 17, 2012.
  1. kw600
    kw600 Road Train Member
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Just under 15k on a brand new kenworth t700 and the HEST indicator has come on three times already. Im new with this auto regen / parked regen stuff; but would i be wrong if i said it shouldnt come on this early in the life on the truck? Thoughts/tips...
  3. olphart
    olphart Medium Load Member
    301
    146
    Feb 15, 2009
    Minden,LA
    It doesn't mean anything is wrong, just letting you know that the exhaust system temp is high from doing a regen.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Mine will come on if it is in a burn cycle and the speed of the truck falls below something like 20 mph. The fan also comes on. It burns so hot it is only a warning. You can probably smell the distinct odor it emits when it is doing so.
  5. kw600
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Even at 15k ? Dealer said around 250k itll have to do a regen? I dont have to do anything when hest light comes on correct?
  6. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Your DPF will be cooking (regen) several times a day, even if the truck is brand new. He is referring to the service where you have to have the center filter of the DPF removed and taken to a shop to have it cleaned. That may be at roughly 250,000 or so.
    Do not need to do anything when the HEST light comes on. I think the idea behind it was not to park the truck over anything that could ignite, perhaps dry leaves, causing a fire. I think the DPF burns at 1600 degrees, but I could be mistaken.
  7. MysticHZ
    MysticHZ Road Train Member
    5,902
    5,726
    May 28, 2010
    The system does regens all the time ... at 250K you will pull the DPF filter and have it baked and flow tested to extend the life of the filter ... cost is around $400
  8. kw600
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Wheres that filter located?
  9. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,381
    Jul 16, 2012
    Bentonville Arkansas
    Ur dealer told u wrong.. these regens happen threw out the day. Slower u run more u need a regen I'm doing one every 2-3 days lol
  10. kw600
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    What about parked regen?
  11. TruckerPete1990
    8,623
    5,381
    Jul 16, 2012
    If u leave switch on u shouldn't have to worry about parked regen..
