Back half of the transmission was just redone 18,000 miles ago. The trans is grinding from high to low. Tried both preselecting and going to the low side once the shifter goes to neutral : grinds both ways. My question is - Did I do something wrong to mess this up? If you think about it the transmission goes from hi to low basically by itself. What are some of your opinions? Was it not put together correctly? It was not put back with genuine EATON FULLER parts.
Hi to Low grind - 13 speed
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 01blackz28, Jun 13, 2012.
synchronizer is bad, or when it was rebuilt if the bull gear that the synchro slides into was not replaced it could have eaten the syncro up. Or it could be just bad parts, either way its got to come back apart, and I highly recommend going back with eaton parts.
bull gear was not replaced. eaton parts for sure.
Synchronizer is bad
You might also check your air regulator pressure to the range valve. If the pressure is high to the range cylinder it will cause rapid wear to the syncronizer and heavy shift engagement.
yep, almost forgot about checking regulator pressures been busy working on isx's instead of trans!
Back half of trans can be removed without pulling trans. I have done it. I have rebuilt these trans. U need the right jack. It is the sincro. In back half.
