high beams not working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by joecitizen, Jul 3, 2009.
  1. joecitizen
    joecitizen Light Load Member
    242
    38
    Mar 15, 2009
    Tucson, AZ
    i have a new to me '93 freightliner fld 120 that i am going thru and undoing all of the mickey mouse stuff that has been done to it. in this process my once working high beams not longer function.
    basically, when i flip the headlight switch down to turn on just the running lights, i hear a relay clicking and nothing works. i can flip the headlight switch up and all lights work, except the high beams.
    ideas on where to start looking (besides the obvious electrical system - need to narrow that down a bit)? wires were "jumped" into the headlight wiring system to get fog lights to work. i did not like the way it was wired and only removed the wiring to the fog lights. obviously i inadvertently did something else to caused the high beams to stop functioning.
    thanks for any possible help.
  3. BigSam
    BigSam Light Load Member
    220
    241
    Mar 23, 2008
    Illinois
    Do you have the ignition switch turned on? On a Freightliner FLD120 you have to have the key (ignition) switch on for the high beams to work.
    dibstr Thanks this.
  4. BigSam
    220
    241
    Mar 23, 2008
    Illinois
    Per the Freightliner FLD120 manual:
    Headlight Switch and Daytime
    Running Lights
    A three-position headlight switch (Fig. 2.8) is used to
    operate the exterior lights. When the switch is up the
    headlights, and all other vehicle lights, are on. All
    vehicle lighting is off when the switch is in the middle
    position. When down, the switch activates only the
    clearance, instrument panel, and marker lights, and
    the taillights. The switch for the headlight high beams
    is built into the turn signal lever. When the headlights
    are on high beam, a green light in the warning and
    indicator light module goes on. The ignition switch
    must be on for the high beams to operate.
    For vehicles built to operate in Canada, switching on
    the ignition and releasing the parking brakes automatically
    activates the headlight low beams (later
    model vehicles) or high beams (earlier model vehicles)
    at half voltage as daytime running lights. The
    daytime running lights will operate until the parking
    brakes are applied; then they will switch off. Turning
    on the regular headlights will override the daytime
    running lights. The vehicle cannot be driven unless
    either the headlights or daytime running lights are
    activated.
    joecitizen Thanks this.
  5. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    yup key has to be on for high beams to work
  6. 2fuzy
    2fuzy Road Train Member
    1,053
    324
    Jun 19, 2008
    Granite Canon,WY
    Does the Highbeam indcator come on?
  7. joecitizen
    242
    38
    Mar 15, 2009
    Tucson, AZ
    Thanks everyone all for the replies...
    Never thought I would need the key one for the high beams to work. When I get back home from the holiday weekend, I will give it a try and report back.
    BigSam...
    Not meaning to be a smart***, but I don't have one. If you have an extra one or know where I can buy one, please let me know. I tried L.A. Freightliner and was told they don't go back that far for me to buy one.
    2fuzy...
    I will check and see...
  8. BigSam
    220
    241
    Mar 23, 2008
    Illinois
    The manual can be downloaded for free on freightliners web site. I PM'ed you a link to the manual.
  9. gafred99
    gafred99 Light Load Member
    155
    12
    May 28, 2009
    Tignall
    Bigsam send me the link also, thanks.
  10. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    left upper part of your fuse panal is the relays for headlights.. the headlight relays also operate your marker lights replace, both the left headlight relay and the right headight relay... also make sure they are not corroded. a windshield that is leaking will soak the fuse panal. then its not a bad ideal to remove and replace all corroded relays
  11. joecitizen
    242
    38
    Mar 15, 2009
    Tucson, AZ
    finally got to the truck today and sure enough, turn the key on and voila...high beams, even the indicator light on the dash is working!
    still got a clicking sound coming from the relay for the trailer...
    thanks again to all who offered input...
    DSK333 Thanks this.
