High coolant and engine oil temperatures normal? D12 Volvo 630
Discussion in 'Volvo Forum' started by kokobongo, Aug 26, 2012.
  1. kokobongo
    kokobongo Bobtail Member
    hi dear
    my truck is volvo 630 , 2007 with D12 ENGINE.
    THE COOLANT ALWAYS STAY FROM 180 -210 FAHRENHEIT AND OIL TEMPERATURE 106 C -110 C ( 222-230 FAHRENHEIT )
    DEALERSHIP SAYS THIS IS NORMAL .
    THIS IS MY 5 TH VOLVO TRUCK AND I NEVER HAD A THIS HIGH COOLANT AND ENGINE OIL TEMPERATURE. BUT 1ST TRUCK WITH VISCO FAN
    ARE ANY ONE KNOW ABOUT IT ,OR ANY EXPIRIENCE ?
    PLEASE HELP, THANKS
  3. Mlaz Bogdanci
    Mlaz Bogdanci Light Load Member
    58
    11
    Feb 5, 2012
    Santa Monica , CA
    Normal for 07 D12 i was worried about this too when i first got my 07 but yes it is very normal i have the same numbers
    kokobongo Thanks this.
  4. kokobongo
    I have recently changed the viscous fan and still same .
    I spend $1000 for nothing
  5. Jetsr6
    Jetsr6 Light Load Member
    131
    46
    May 20, 2011
    Mechanicsville, VA
    I know I'm a little late on this but. My temp shows 172 or so. I have my egr crossover tube blocked in the front of the motor. No hot exhuast gases back in to motor. I'm looking for a hotter thermostat now.
  6. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    your munbers are about the same as my 2006 d12
  7. bravoo67
    bravoo67 Light Load Member
    252
    35
    Mar 15, 2012
    Brooklyn NY
    mine 06 D12D 465HP during normal driving oil temp is 210.. up long hills it gets up to 220 but rarely.. now in the winter is around 200-205.. coolant is around 180-190 most of times
  8. jdmach77
    jdmach77 Light Load Member
    54
    9
    Jan 19, 2012
    New Jersey
    Normal, cooland 188/195 oil 205/220 on Hill climbing .....!
  9. bobeagle
    bobeagle Bobtail Member
    12
    4
    Jan 15, 2011
    PLANO,TX
    I have a D12 volvo 780 model2005. Runs very well but coolant temp very low sometimes 128 degrees in winter. When it gets this low, AC/Heater wont give me heat!! when outside temp gets better like 50 coolant rises to b'tween150 to 160 but never gets to 170 except in real hot weather in summer. When I cover the front grill with cardboard it gets warmer and cab gets heat. Whet it shows too low on temp gauge on dash, I stop, open hood radiator cap and stick finger .....and I find coolant just warm, even after an upgrade hauling a regular ..like 30,000 lbs.
    Anyone with an idea about such low temps,
  10. QUALITYTRUCK
    1,810
    1,773
    Jun 14, 2009
    romulus,mi
    change your thermostat.good luck.
    flood Thanks this.
  11. bobeagle
    12
    4
    Jan 15, 2011
    PLANO,TX
    Thanx QUALITY TRUCK. I'll give feedback here as soon as I have new thermostat fitted. Suggestion appreciated.
