High Idle speed problem
Discussion in 'International Forum' started by eng.moh.4u, May 8, 2017.
  1. eng.moh.4u
    eng.moh.4u Bobtail Member
    40
    4
    Jan 13, 2017
    After the workshop clean driver cabin for my 7500 DT570 truck i found that:
    1- When starting truck the RPM increase to 1700 RPM without depressing accelerator pedal.
    2- When I disconnected the APS/IVS connector the rpm go down to normal range
    3- No Engine codes appeared
    Is this the APS/IVS problem and how to fix it?
  3. Heavyd
    Heavyd Road Train Member
    7,815
    6,267
    Feb 4, 2009
    Make sure they didn't get something stuck under the pedal and it is partially held down.
    eng.moh.4u Thanks this.
  4. eng.moh.4u
    40
    4
    Jan 13, 2017
    I reconnect APS/IVS 10 times and it works fine now
