High Idle - Why?
Discussion in 'Truck Stops' started by PacoTaco, Dec 20, 2016.
  1. PacoTaco
    PacoTaco Medium Load Member
    492
    2,440
    Apr 16, 2016
    South Texas
    I usually manage to avoid taking my 10 at a truck stop, but it seems like every time I do I'll initially manage to get in between two quiet trucks. Then ten minutes later the guy next to me leaves freeing up the spot for the next guy who pulls in and is going to high Idle all night. Is there a valid reason for this? I see it all four seasons.
    D.Tibbitt, DTP and Dave_in_AZ Thank this.
  3. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    Increases the oil pressure for better lubrication. Alternator puts out more amps to keep the batteries charged. Engine runs smoother. Recirculates more fuel to the tanks to keep fuel warm and prevent gelling. Generates more heat to help maintain warmth inside (winter). AC compressor does its job better (summer). Etc., etc., etc...
  4. PacoTaco
    492
    2,440
    Apr 16, 2016
    South Texas
    Those are all good reasons - but WHY do they always end up next to me? Think I'll start nosing in from now on.
  5. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    Because there was an empty space and they needed to park?
    D.Tibbitt, Smut, Eowyn and 10 others Thank this.
  6. Dakota Dave
    Dakota Dave Bobtail Member
    26
    15
    Oct 16, 2014
    Did you check to see if there is a sign on your trailer that says park here ?
    RedRover, Dave_in_AZ and PacoTaco Thank this.
  7. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Trucks with DPF and SCR systems must use a high idle also.
    Dave_in_AZ, bzinger and PacoTaco Thank this.
  8. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
    Yup this is why I idle up to around 8-900 as that where my ISX will do its manual regens. For some reason it's programed to cancel regens when I set the cruise at anyhing other the 8-900 and I have to set the cruse to cancle the 5 min idle shutdown timer. I also lock the fan on so its at least a constant noise instead of an on/off noise as I think its more polite.
    PacoTaco Thanks this.
  9. MACK E-6
    48,927
    226,811
    Pickup trucks too?
  10. MACK E-6
    48,927
    226,811
    You could always put traffic cones in the spots on either side of you. :laughing6:
    Knucklehead Thanks this.
  11. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    They just back over them.
