High oil temperature Volvo Vnl 780
Discussion in 'Volvo Forum' started by umarbek98, Jun 3, 2020.
  1. umarbek98
    umarbek98 Bobtail Member
    7
    Jun 3, 2020
    Hello everyone, I started having this issue yesterday where I have the information warning come on and high oil temperature. I thought it maybe because it’s around the time I need oil change I changed my oil and still my oil temperature is going above 270 Fahrenheit
    And stop warning ligh comes on and truck looses power and after stopping shuts off.
    2016 Volvo VNL 780 D13 I shift
    Trucking Jobs in 30 seconds
  3. umarbek98
    7
    Jun 3, 2020
    Coolant temperature is normal when I start driving 60+ mph oil starts going high temperature when I go below 60 it goes back to normal
  4. Doealex
    Doealex Medium Load Member
    403
    712
    Feb 21, 2018
    Does your fan kick in?
  5. umarbek98
    7
    Jun 3, 2020
    Yes it does kick in and fan is working perfectly fine
  6. MM71
    MM71 Medium Load Member
    540
    525
    Jun 28, 2008
    AZ
    I am not a D13 aficionado so I should keep my mouth shut. But, if your water temp is not high. Temp your oil pan with a infrared thermometer, see if its similar to what the sensor is reporting. If you feel like throwing parts, I would say replace oil temp sensor first. If that doesnt fix your issue, you have a plugged up oil cooler or a spun bearing causing all the heat.
    I glide 47 and umarbek98 Thank this.
  7. umarbek98
    7
    Jun 3, 2020
    Will try it out thanks for the information
  8. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    2,921
    3,764
    Mar 19, 2018
    Nashville
    Prepare to lose a rod bearing. Oil temp high, coolant normal.....
    Doealex Thanks this.
  9. umarbek98
    7
    Jun 3, 2020
    I am confused could you explain your answer little more pls thank you
  10. Trucking in Tennessee
    2,921
    3,764
    Mar 19, 2018
    Nashville
    When a rod bearing is hurt, it heats up the metal, thus heating up the oil. The coolant won't reflect that in some cases. What do you consider running hot as far as oil temp?
  11. umarbek98
    7
    Jun 3, 2020
    I replaced the piston jet cooler and cleaned the oil separator with brake cleaner and the truck has been running fine with heavy load no problems 2nd day
    KB3MMX and Doealex Thank this.
  • Draft saved Draft deleted
