High SWR with magnet antenna
Discussion in 'CB Radio Forum' started by sly-fox, Jan 31, 2021.
  1. sly-fox
    sly-fox Bobtail Member
    Jan 30, 2021
    HEllo, Im fairly new to radio, and so, some of my friends and I put a K-30 (magnet) antenna on a steel plate drilled into the top of a tower made of 2/4s, connected through a small gap under my door (not crimping the coax, its a large enough gap I can easily slide the coax in and out of) connected to a Cobra 29 (powered by an 120V AC to 12VDC power supply), however, the issue is my SWR is above 3 on an swr meter I picked up. would anyone have any clue as to why?
  3. Timin770
    Timin770 Road Train Member
    1,657
    1,758
    May 27, 2011
    Canton, GA
    I would think you'd need a very large steel plate to make it work. There are some really CB-smart dudes who post here, so hopefully they can weigh in
    Crude Truckin' Thanks this.
  4. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,395
    6,598
    Oct 22, 2016
    North Dakota, Eh?
    Not enough ground plane for that magnetic antenna I'd say. Just go buy a base station antenna and you'll have 10x the results of that magnetic. @rabbiporkchop
    Timin770 Thanks this.
  5. Crude Truckin'
    2,395
    6,598
    Oct 22, 2016
    North Dakota, Eh?
    Is your swr 3:1 across all 40 channels?
  6. Crude Truckin'
    2,395
    6,598
    Oct 22, 2016
    North Dakota, Eh?
    If you have a multimeter, also check impedance from center conductor to the shield on the coax. How long is the coax?
  7. Powder Joints
    7,657
    7,739
    Sep 25, 2007
    Rosamond, SoCal
    Sounds like a open shield, check the coax, also open the bottom (probably peeling the tape back) and check the connections at the base connector in the mount, if one of your friend soldered the PL on check it for a short/open also.
  8. Powder Joints
    7,657
    7,739
    Sep 25, 2007
    Rosamond, SoCal
    In general, make sure the coax is grounded to the antenna structure ( Oh yea you can't, its wood, hummmm) , it can use a mast or tower (if you had one) to reflect off although it will give it kind of a weird radiation pattern. Mount a 10' pipe to your wood to, wood is a terrible antenna structure. Cheep seldom works in radio, usually makes you spend twice. Buy once cry once, your 2x4's would make you a better radio bench, goto the Home Peepot and get a couple of 10 dollar masts.
    Im not telling you to go buy my 100' rohn tower, but a couple of tv antenna masts and a cheap ground plane from Ebate will help you tons.
  9. Ridgeline
    22,365
    115,986
    A hillbilly antenna, haven’t heard one made in a long time.
    can’t do it with a magnet mount, just get something that you can mount to the plate, like a k40 trunk lip mount then take a 16 gauge wire, attach it to the plate then run it down to the 2x4 about 16 to 18 feet long. Your swr should drop.
  10. sly-fox
    Jan 30, 2021
    Thank you all for the replies, Ill try the mast/tower idea instead of the wood, and ya, all channels are above 3 swr, also IU checked with my meter, and the sheild on the coax is fine and the antenna is fine. Thank you. Ill reply back with results and such.
